Author Topic: Safe Mode Wont work?  (Read 5822 times)
Offline Kaz
« on: September 21, 2007, 09:28 »
Hi Everyone,
Since I had that Virus Iv been cheeking everything ''think I'm getting a bit paranoid now', anyway I have to run a AVG spyware in safe mode I tried doing this yesterday and it caused all sorts of problems anyway Iv sorted that out now, but I still  can't boot up into Safe Mode I go to F8 and get the menu
Safe Mode
Safe Mode Networking
Safe mode ????????
Iv tried all of them and It just keeps going back to the menu until I say go back to windows then it boots back to windows, any ideas as to what I can do please :dunno:
Re: Safe Mode Wont work?
« Reply #1 on: September 21, 2007, 09:41 »
Not sure if this will work, but you could try it, Kaz.
Go to Start > Run, and then type in msconfig and hit Enter and the system configuration utility box comes up.
You should see several tabs across the top. One of them, when selected, has a box you can tick that says "Safe Boot".  Tick that box, and then click Apply and OK and it will prompt you to restart the computer, which should then start in safe mode.
To change it back so that it boots into normal Windows, you have to go back into this same box to untick the "Safe Mode" box or it will continue to boot in Safe Mode.
However, there does seem to be an underlying problem as to why it won't boot into safe mode via the normal method, which hopefully someone will come up with an answer to.  I just hope that the virus you had, or the removal of it, hasn't damaged Windows, in which case, you may have to consider a repair or re-installation of Windows.
Offline Kaz
« Reply #2 on: September 21, 2007, 10:13 »
Hi Simon,
Have done that and that's what gave me the big problem couldn't still get into safe mode and couldn't get back into windows to uncheck safe mode I had to go back to my very first backup that came with PC and then use a backup I did day before yesterday to get it back on line again
''thank god for backup's'' :laugh:
When I went back to my first backup I did a test to see if it would go into safe mode and it did, but I have so much stuff on my PC a the moment I really don't want to go down that path just yet if I don't have to Iv tried repairing for the win CD that didn't work either, so I am looking around for ideas at the moment haven't got anywhere yet :dunno:
« Reply #3 on: September 21, 2007, 18:55 »
I think you should look into registry repair software. Ccleaner has an average one, but the best i've come across is called registry mechanic. I don't know if it will solve your safemode problem, but I'd say half the time i have a funky windows problem like this checking the registry will resolve it.
Offline Kaz
« Reply #4 on: September 21, 2007, 19:44 »
Thanks Bob,
at the moment Im doing just that :crazy:
and Im trying anything if Im honest I have tried registry Mechanic it found a few things nothing drastic but it hasn't solved my problem, but thanks for the input, Ill carry on trying :dunno: only been on this since 7.30 this morning think it's time for a little drinkypoos!
Offline Kaz
« Reply #5 on: October 14, 2007, 14:43 »
Well I am b back on line again now My pc guy couldn't fix the problem with safe mode, he had never seen anything like it, so I have had to do a complete install an start again, but it's fixed now I have one problem now and Im going to post a new topic on it
Thanks for all the help again
« Reply #6 on: October 14, 2007, 15:02 »
I would advise you invest in something like Acronis True Image, and use it regularly to make backups. If you get hit with this sort of problem again, it's the work of minutes to restore your machine to a working state.
Offline Kaz
« Reply #7 on: October 14, 2007, 15:13 »
Hi Rik Bean,
I do and have Acronis and make regular backups since I got Acronis, but it would appear that my problem what ever it was that caused this was on my PC before I got to use Acronis every backup I re-installed carried the ''Safe Mode Problem'' I ean it's not every day you use the Safe Mode is it? and it was only by chance that I found it when I did I thought I had a virus so I downloaded some spyware that need to boot up in Safe Mode and thats when I found it I spent hours trying to sort it and with help from my Pals on here, even my computer Guy couldn't fix it, anyway it's sorted now a lesson to be learned
Thanks  ;)
« Reply #8 on: October 14, 2007, 15:29 »
Now you have a clean machine, Kaz, it's worth getting into an Acronis regime. The first time you have to restore the OS, you'll probably suffer a few sweaty palm moments as you wonder if it really works, but after that, the comfort factor is immense.
Offline Kaz
« Reply #9 on: October 14, 2007, 15:38 »
Yep,
Im really  happy with it I back up every time I install new prog it just takes minutes :thumbs:
« Reply #10 on: October 14, 2007, 16:18 »
That's the best way, Kaz, plus before any updates, of course. I also have a regime of backing up all data and settings to two external USB HDs daily, plus an internal SATA HD. I put a subset of data onto a DVD-RW (one per day, so I have some rollback available) and another subset on a port-powered USB HD (which I can quickly switch to any machine). Call me paranoid, but I haven't lost any data in more than 18 years.
« Reply #11 on: October 14, 2007, 18:22 »
Call me paranoid
Paranoid.
Paranoid was once known as Rik Bean.
« Reply #12 on: October 14, 2007, 18:26 »
 :P
« Reply #13 on: October 14, 2007, 20:37 »
Good heavens, no wonder you never leave your PC!   :o ;D
« Reply #14 on: October 15, 2007, 09:53 »
I do it on all three machines, Simon, albeit slightly less on the lappy. It's like painting the Forth bridge. ;)
