Author Topic: LCP Down  (Read 1369 times)
Offline DJ
LCP Down
« on: September 21, 2007, 17:41 »
Hi All,
Friend haveing problems with their internet connection after a power cut.
They used to use a Netgear DG834m wirless router but it now states LCP Down, CHAPS failed authentication.
Now if they use the original ZyXEL ADSL modem they got with their internet all works - however they don't have wireless with this.
A few things;
At no point have I had to enter a username and password for the ZyXEL modem and the Netgear is showing username as Guest and password as password.
I think their ISP is EasyNet however it is provided by their company (as a business line) so not really sure.
I have already updated the router to the latest firmware version.
Any suggestions to make the Netgear work again!?
Thanks, DJ
Re: LCP Down
« Reply #1 on: September 21, 2007, 18:44 »
There's a little reset button on the back of the router, DJ.  This will reset all settings to default.  Might be worth a try.  Second thing would be to check if a user name and password is required to log on.  I've read somewhere else about there being an issue with these routers, following power outages, but I can't remember the exact details of what happens, or the remedy.  I'll try to find out more if none of the above works.
Offline DJ
Re: LCP Down
« Reply #2 on: September 21, 2007, 19:24 »
Thanks Simon,
Yep tried the hardware reset pin in back thing  :P
Still confused if they need a username and password or not. Have tried using the option of 'No User Name Required' and entering Username as Guest, which it puts in itself, but still no joy!
Thanks, DJ.
Re: LCP Down
« Reply #3 on: September 21, 2007, 22:37 »
Sam very recently published a list of default usernames and passwords at
http://www.pc-pals.com/smf/index.php?topic=20125.0
I can't see Netgear DG834m but Netgear DG834g is there sporting a disarmingly simple username and password!   ;D
Offline DJ
Re: LCP Down
« Reply #4 on: September 21, 2007, 23:01 »
Thanks Clive,
I can access the router fine. Its the username and password for the internet connection that I'm not sure if I need.
I can get connected using the other modem, but the netgear one produces this error message.
DJ
Re: LCP Down
« Reply #5 on: September 21, 2007, 23:37 »
If you look at properties for the modem then that should show the correct username, the password will be asterisked out.
Download a little free program from passware called Asterisk Key and that will show you whats hidden beneath the astersks  :)
Re: LCP Down
« Reply #6 on: September 21, 2007, 23:43 »
Good heavens Sandra - is there no limit to your talents?   ;D
Re: LCP Down
« Reply #7 on: September 21, 2007, 23:45 »
Well I am struggling to find an extremely rich toy boy at the moment  ;)
Re: LCP Down
« Reply #8 on: September 22, 2007, 01:13 »
Don't struggle, you'll have more success.  :devil: :scoot:
