Author Topic: Acronis Drive Cleaner  (Read 1919 times)
Offline DJ
« on: September 22, 2007, 13:21 »
Hi All,
Can any one recommened a freeware alternative to Acronis Drive Cleaner.
I require software that will delete files from an old drive.
Cheers, DJ.
Re: Acronis Drive Cleaner
« Reply #1 on: September 22, 2007, 13:55 »
Discwizard has a zero fill option that will write a zero to each part of the drive thereby deleting the data instead of just formatting the drive, which leaves data intact but just removes its record.
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=DiscWizard&vgnextoid=d9fd4a3cdde5c010VgnVCM100000dd04090aRCRD
Its a free tool and works on any make of drive.
I have just read the info and it doesnt seem to have the same option for zero fill as the older version did which was small enough to run from a floppy disc :(
« Last Edit: September 22, 2007, 14:07 by Sandra »
Offline DJ
« Reply #2 on: September 22, 2007, 14:36 »
Ok thanks Sandra - will have a look.
Think the normal Format drive will be ok for me, just want to clear out an old drive then I will be reusing it - so no real security issues.
Thanks, DJ.
« Reply #3 on: September 22, 2007, 14:39 »
OK but if you need to zero fill it, if the seagate one no longer includes the option, then this one does it :
http://www.killdisk.com/
Has free and pay for versions that boot from either floppy or CD, the free one should be ok for most people  :)
« Reply #4 on: September 23, 2007, 21:09 »
I have an easy to use zerofill that works off a bootable cd. I think it is either a seagate or maxtor bootdisk. I use to use it for those hard to remove recovery partitions some manufactures install. I know i have a few others sitting around, but I'm sorry to say I haven't a clue where they could be. Normally its easier to just stuff it into my enclosure and format it using windows.
