November 27, 2024, 22:54
Technical Help & Discussion
burning software
Topic: burning software (Read 1071 times)
Baz
Established Member
burning software
October 04, 2007, 21:23 »
what cd/dvd burning software do people use. Are there any decent free ones available.
At the moment am using nero as a lot of people probably do but want to try others for comparison.
Re: burning software
October 04, 2007, 21:31 »
I've always used Nero. Tried Roxio and didn't get on with it, along with the fact that it takes over your machine if you let it. I believe there are one or two free ones,
DeepBurner
springs to mind, which comes in a Free and Pro versions. I haven't found one yet that does all of what Nero does.
Baz
Established Member
October 04, 2007, 21:34 »
cheers Simon, I too tried Roxio ages ago but didnt like it either
have been thinking about Deepburner but am unsure if it will work with my DVD 'back up' prog
whereas nero does.....know what i mean
October 05, 2007, 00:45 »
Another Nero fan here. I used to use Roxio maybe 12 years ago, but that was when it was still Adaptec.
Reno
Established Member
ø¤º° bob °º¤ø
October 05, 2007, 03:46 »
I use an older version of nero over the newer ones. For some reason v6 doesn't error out like v7 does on my machine. Plus the older versions are void of all the added junk that is being installed with nero these days.
gmax
Established Member
October 05, 2007, 07:55 »
I use Nero 7.5.7.0 , it works well with xp & vista, just do a custom install no need to load all the junk.
burning software
