Author Topic: Astroburn - A new free burning program  (Read 1303 times)
« on: November 05, 2007, 09:05 »
The makers of Daemon Tools have announced a partnership with Astroburn, a new free burning application. If you're wanting to get away from the Nero bloatware, then you should give this program a try. The download size is about 4MB. Like Daemon Tools, it uses the SPTD driver, which requires a reboot when you first install it.
ImgBurn is still smaller and does not require the SPTD driver. However, the advantage of Astroburn is that it has an easier to use interface, so it would be a good program for people who are not exactly computer experts.
And like Daemon Tools, don't forget to decline the toolbar installation.
http://www.disc-tools.com/download/astroburn
Re: Astroburn - A new free burning program
« Reply #1 on: November 05, 2007, 09:50 »
hmm, might give it a go later
Offline Softix
« Reply #2 on: December 15, 2007, 16:28 »
Sounds good, thanks for sharing.
I really want to stop using Nero since the new version I upgraded isn't working in my computer after successfully installation.
If I can get a software like it or even better, it's welcome. Besides, I have used Daemon tools software and I think this one will be good to try.
