Author Topic: Driving Test  (Read 421 times)
Driving Test
« on: November 14, 2007, 23:45 »
You are driving in a car at a constant speed.
On your left side is a 'drop off' (The ground is 18-24 inches below the level you are travelling on).
On your right is a fire engine travelling at the same speed as you.
In front of you is a galloping horse which is the same size as your car and you can not overtake it.
Behind you are two more galloping horses. The horses are also travelling at the same speed as you.
What must you do to safely get out of this highly dangerous situation?
Think about it, then scroll down for answer...
Get off the merry-go-round!
Re: Driving Test
« Reply #1 on: November 15, 2007, 09:02 »
 :clap:  10/10
