Author Topic: file converting  (Read 1984 times)
Offline Baz
file converting
« on: November 18, 2007, 19:09 »
anyone use any good file converting progs, mainly for music files. wav to mp3 etc
thanks
Re: file converting
« Reply #1 on: November 18, 2007, 20:30 »
Offline Baz
Re: file converting
« Reply #2 on: November 18, 2007, 21:27 »
thanks Simon have already looked at that site but couldnt find any thing for me...... unless I just missed it. was looking more for a utility to download rather than an online option.
Re: file converting
« Reply #3 on: November 18, 2007, 22:05 »
audacity is useful for audio
Re: file converting
« Reply #4 on: November 18, 2007, 22:40 »
Could also try this one, Baz:
http://www.freerip.com/
Doesn't Windows Media Player also perform this task?
Offline Softix
Re: file converting
« Reply #5 on: December 15, 2007, 16:32 »
jetAudio isn't only a media player software, it contains many tools for converting audio, ripping cds, burning cds, etc. You should give it a try, since it can convert tons of audio files into different formats. I recommend you to use it if you are still looking for an audio converter.
