Author Topic: UK broadband use reaches new high  (Read 2409 times)
« on: November 22, 2007, 09:01 »
Almost nine out of 10 UK net users are connecting via broadband services, official figures reveal.
http://news.bbc.co.uk/1/hi/technology/7105242.stm
Re: UK broadband use reaches new high
« Reply #1 on: November 22, 2007, 09:58 »
And some of them actually get above dial-up speeds!  :devil:
« Reply #2 on: November 22, 2007, 10:16 »
Mine rarely does these days!  Today is an exception as I'm getting 3 meg but 0.2 meg has been the norm these past few weeks.   :bawl:
Good old BT. It was fine until I locked myself in for another 18 months.  :bawl:
« Reply #3 on: November 22, 2007, 14:38 »
Surely it's only the first 18 months that counts as the minimum term, Clive?  You've been with then forever, so I can't see how you're still tied to them, unless you have entered into a new contract for another service.
« Reply #4 on: November 22, 2007, 16:09 »
Yes, I did when I signed up for Home Hub and a cut of 2 quid on my extortionate monthly charge.  At this point in time it's no big deal because Mrs Clive's employers pay the bill.  But I wasn't prepared for the debilitating drop in speed that has frequently taken place since I signed up.
« Reply #5 on: November 22, 2007, 16:12 »
Thought so... it's dropped to 0.234 meg.
« Reply #6 on: November 22, 2007, 16:59 »
Line stats?
« Reply #7 on: November 22, 2007, 22:12 »
Good heavens it's now leapt up to 6.208 Meg! Upstream is 0.448 meg. Data transmitted 68.78 Received 274.32 meg.
« Reply #8 on: November 22, 2007, 22:26 »
 :dunno:
« Reply #9 on: November 23, 2007, 00:15 »
Must admit I am a little disappointed in my speeds since I moved to BeThere.co.uk
I was expecting around 14 to 18mbs but seems to be only around 11 to 12mb down and 1.2mb up.
Its a lot better and cheaper than I was getting off Pipex and I have had some torrents coming in at over 550kbps and a few downloads off MS sites at 1.2mbps, I had never seen the download window show anything in mbps before and thought it was slow until I noticed it was in mbps and not kbps  :)
I dont really understand the router stats, apart from the bandwith ones Rik but if you can make any sense of them here are mine :
Link Information
Uptime: 2 days, 7:04:35
Modulation: G.992.5 Annex A
Bandwidth (Up/Down) [kbps/kbps]: 1,152 / 12,328
Data Transferred (Sent/Received) [MB/MB]: 613.58 / 757.66
Output Power (Up/Down) [dBm]: 12.0 / 19.0
Line Attenuation (Up/Down) [dB]: 15.0 / 31.0
SN Margin (Up/Down) [dB]: 8.5 / 5.5
Vendor ID (Local/Remote): TMMB / µ
Loss of Framing (Local/Remote): 4 / 0
Loss of Signal (Local/Remote): 1 / 0
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 3,135 / 0
FEC Errors (Up/Down): 0 / 860,321,556
CRC Errors (Up/Down): 7,570 / 6,557
HEC Errors (Up/Down): 3,738 / 2,283
Apparently they have DLAM running or something like that for the first 15 days to try and get the best speed and most stable connection.
I think I am past that so may ask them to remove it as some people have noticed an increases in speed after they have removed their monitoring thing.
« Reply #10 on: November 23, 2007, 00:38 »
Hi Sandra
The DSLAM is the bit of kit you connect to, the monitoring is usually done by separate software - though I'm not that strong on LLU products.
For the attenuation you have, 31db, a sync speed of 12,328k at a noise margin of 5.5db seems pretty fair. LLU operators don't use the BT profile system, so your line is running as fast as it can.
The one thing that would concern me is the FEC error count. At 860M in 2.3 days, it's a bit high, and suggests you are probably losing some packets to noise, thus reducing your overall throughput.
How is your router connected, eg to the master socket, or at the end of an extension? It may be that a few internal wiring tweaks would help.
« Reply #11 on: November 23, 2007, 00:39 »
How about attenuation and noise margin, Clive?
« Reply #12 on: November 23, 2007, 02:00 »
Its a router direct into the BT master socket via a splitter Rik.
The Be forums have suggested that some people try removing the face plate and connecting directly into the socket behind it so as to elimiminate any extensions to see if that improves things but I only have one extension so I dont think that would affect it.
Some have suggested disconnecting the bell wire can improve things as well.
A few people have mentioned getting high FEC errors but the Be people dont seem to be too worried about them for some reason ?
To be honest I am quite happy with the speeds I get but you know us gals, we always like a bit more than we can usually get  ;)
« Reply #13 on: November 23, 2007, 02:15 »
Seems detached compared with the old school methods for keeping busy during a snow in.  :crazy:
« Reply #14 on: November 23, 2007, 09:41 »
Sorry Rik.  Computer says "no".   :dunno:
