Author Topic: Optical mouse crash  (Read 12342 times)
Optical mouse crash
« on: November 11, 2002, 18:15 »
I have an optical mouse and sometimes when I use the central wheel to scroll down, it causes a total freeze up.  Alt/Ctr/Del seems disabled and all I can do is shut the whole machine down.  Are there any tweaks I can perform to prevent this happening?
Re:Optical mouse crash
« Reply #1 on: November 11, 2002, 18:34 »
Well Clive, I can't say I've ever had the pleasure of that problem with my optical Intellimouse Explorer, but you could try searching for a driver update.  Also, if it's a mouse that you had before you upgraded, it might be worth checking for a more XP-compatible update to the mouse software, too.
Try it on another machine and see if you can break that one.  :o
If none of the above works, I'm out of ideas.  Good luck!   ;)
« Reply #2 on: November 11, 2002, 18:34 »
Oh heck Clive, that shouldn't happen ??? Especially with XP.
Did I remember to install the Logitech software? If I didn't, it might be worth doing that. In fact even if I did install it, see if there is a later version available on www.logitech.com that you can download and install :)
« Reply #3 on: November 11, 2002, 18:44 »
Yes, the Logitech software is loaded, but I'll try that download and see if it improves matters.
« Reply #4 on: November 11, 2002, 18:50 »
There are no updates since May so I probably have the latest one anyway.
« Reply #5 on: November 11, 2002, 18:54 »
Do it anyway Clive, just in case something's been corrupted.
« Reply #6 on: November 11, 2002, 19:05 »
I've done it!
« Reply #7 on: November 11, 2002, 19:14 »
I've done it!
But has it worked?  ;)
« Reply #8 on: November 11, 2002, 19:19 »
I don't know yet!  It only happens about twice a day.   ;D  Ask me Friday!   ;D  ;D  ;D
« Reply #9 on: November 12, 2002, 08:33 »
It froze again this morning so the download hasn't worked.
« Reply #10 on: November 12, 2002, 09:41 »
OK Clive. Back to basics time.
Uninstall the Logitech software and try the mouse without it loaded. That will tell you whether it is a software or hardware problem.
« Reply #11 on: November 12, 2002, 11:15 »
OK I'll give that a try and let you know the result.   ;D
« Reply #12 on: November 12, 2002, 12:44 »
I've uninstalled the logitech mouse driver and the mouse still works.  I'll keep you posted on developments.   ;D
Edit:  I've just tried some pretty vigorous scrolling which would have previously guaranteed a crash and so far so good.  Early days though.   ;D
« Reply #13 on: November 12, 2002, 13:40 »
Well, I never installed the software for my optical mouse, and it seems to do everything anyway!!   :)
Offline Barra
« Reply #14 on: November 12, 2002, 17:20 »
What sort of broadband modem do you have clive? Is it a  usb one? If so, it's the same as me and sometimes if I'm doing some heavy down or uploading it semms to slow up my mouse.
