Author Topic: Merge Partitions  (Read 1231 times)
Offline DJ
Merge Partitions
« on: December 01, 2007, 22:41 »
Hi All,
I've just restored my laptop back to factory settings and installed only the software I need.
However it has created a D drive of 5gb and the C drive with the rest.
I want to either merge the two - to have one C drive.  Or delete D and extend C to cover all the disk space.
i have download trial versions of Partition Magic and also Acronis Disk Suite, but none can peform the operation in trial mode.
Is there any way I can perform this with free software or do I need to shell out some cash to make this happen?
Cheers, DJ.
Re: Merge Partitions
« Reply #1 on: December 02, 2007, 00:14 »
XP or Vista, DJ?  I don't know the answer, but I know someone will want to know that!   ;)
« Reply #2 on: December 02, 2007, 00:33 »
If you get a copy of Hirens boot disk then that has many disk management programs on it.
I merged 2 partitions on Vista with it a couple of weeks ago.
This is the latest version DJ, the one I used is earlier so this should work ok :
http://maxt.dk/archives/2007/10/15/hirens-bootcd-93/
Edited to add link.
« Last Edit: December 02, 2007, 00:56 by Sandra »
Offline DJ
« Reply #3 on: December 02, 2007, 09:48 »
Its on XP Simon.
Thanks Sandra, thought you would know! - Will have a go later day.
Cheers
Offline DJ
« Reply #4 on: December 02, 2007, 13:12 »
Thanks Sandra - worked a treat!
The CD has lots of useful tools on it - one for the safe pile I think.
Right - off to start Christmas Shopping  :santa:
DJ
