Author Topic: Help! There are ants in my PC  (Read 1177 times)
« on: December 05, 2007, 13:38 »
It is sometimes possible to recover lost data if you, for example, suffer a hard drive failure, but often the best way to protect your valuable files is to use common sense.
But many people don't, according to Kroll Ontrack, a data recovery specialist, which has today published its top 10 list of data disasters that it encountered this year.
One man in Thailand found out the hard way that you shouldn't use insect repellent to rid an external hard drive of a colony of ants - not if you want to hang on to your precious data, anyway.
And closer to home, one Brit - a scientist no less - was so frustrated by the squeaking noise coming from his hard drive that he drilled through the casing and poured some oil in. The squeaking stopped, as did the hard drive.
"We're always fascinated by the extraordinary things people do to data that is often irreplaceable," said Phil Bridge, Managing Director at Kroll Ontrack UK.
However, both of these cases, along with several other daft tales, had a happy ending as the data initially thought to be lost was eventually recovered.
"What is even more astonishing, though, is the technology our engineers are continually developing to recover information and memories. We can often perform a successful recovery from what may seem to be a hopeless case ? proving that you should never give up," Bridge continued.
www.ontrackdatarecovery.co.uk
Offline Baz
Re: Help! There are ants in my PC
« Reply #1 on: December 05, 2007, 14:07 »
interesting  one there about a USB stick that went through a wash cycle and didnt work. ;D ;D
My sons did just that when he left it in his trouser pocket.......it is still working now though. good job it had the cover on the end :D
« Reply #2 on: December 05, 2007, 20:26 »
That's quite impressive, given that my car key died after just one wash!   :bawl:
« Reply #3 on: December 05, 2007, 20:54 »
That must have hurt Simon.   :(
« Reply #4 on: December 05, 2007, 21:42 »
It just means that the button doesn't work to set the alarm, but the key still opens the doors.
« Reply #5 on: December 05, 2007, 23:23 »
Oh well that's not so bad.  Replacement remotes are off the wall these days - as are most car parts.   :(
« Reply #6 on: December 05, 2007, 23:50 »
Indeed, if I can be bothered to look for one.   :o:
« Reply #7 on: December 06, 2007, 08:12 »
My little 100mb usb stick went through the wash. Still works too. They're normally ok as long as they don't go through the dryer and they sit for a few days to dry out.
