Author Topic: Search Engine in IE  (Read 1450 times)
Offline Delgado
Search Engine in IE
« on: December 14, 2007, 07:32 »
Anyone else had this problem?
My search engine default is constantly returning to Live Search in IE7.
Im constantly resetting it to Google as the Default, but after a reboot it resets itself. Only been happening lateley. Could this be another attempt by Microsoft to control again?
  HAPPY CHRISTMAS TO YOU ALL ALSO!
 :crazy: :crazy:
Offline Baz
Re: Search Engine in IE
« Reply #1 on: December 14, 2007, 13:56 »
Hi,
I dont know exactly but if you say you keep changing it back to Google, is that from the 'search' side bar that opens then 'customize', I would guess it might be a registry change what you need to do.
do a google and find what you need to change. (no pun meant there :D :D)
some one else will be able to help you better than me
« Reply #2 on: December 14, 2007, 16:12 »
If you use adaware, after running it, it automatically puts in msn search page.  You have to go into options on adaware and set google as your default browser.
« Reply #3 on: December 15, 2007, 03:48 »
Some Antivirus softwares reset the homepage also.
Offline Delgado
« Reply #4 on: December 15, 2007, 09:23 »
Thanks for replies-
Lona, I dont use Adaware, but maybe CCleaner could be the prob.
Reno, I have been trying McAfee Internet Security, maybe thats the cause.
Anyway, Ive now taken out McAfee, and will see how it goes.
Simon could be right!  Firefox may be the way to go!!!!
  :merry:
« Reply #5 on: December 15, 2007, 10:53 »
 :o:
Offline Delgado
« Reply #6 on: December 16, 2007, 08:54 »
Transferred all my favourites to firefox!!!
Had nothing but trouble with IE7 since I had an update come down. Freezing-site not available-what the f---.
Talk about a mess-they block up against security risks, and ruin everything else!!!!
 What with that and my new puppy pooing everywhere     :crazy: :wtf: :merry: :hny:
« Reply #7 on: December 16, 2007, 11:41 »
:welldone: DG!!  Any problems, give us a shout.   :santa:
Offline Delgado
« Reply #8 on: December 16, 2007, 12:09 »
Thanks-
 You any good at clearing up Puppy mess?
 :santa:
« Reply #9 on: December 16, 2007, 12:15 »
 :ack:
