Author Topic: Vista deleting files  (Read 2658 times)
Offline Moreno
« on: December 28, 2007, 19:48 »
Hi guys,
Am struggling with Vista and all the flaming permission boxes that keep coming up!!!  :ack:
Is their anyway of turning these off? Also when I try to delete big files (video) that I have transferred to my drives it firstly ask for permission then basically tells me I do not have the permission....any one know the problem?
Re: Vista deleting files
« Reply #1 on: December 28, 2007, 20:14 »
Assuming you are the Administrator, if you go to Control Panel > User Accounts, you should see a link to Turn User Account Control on or off.
You should bear in mind though, that UAC is a security measure, and not only alerts you to what you might be doing to the system at administrator level, but also what outside forces, such as a malicious program, might be attempting to do, so disabling UAC may compromise your computer's security, and you do so at your own risk!  :)
Offline Moreno
« Reply #2 on: December 28, 2007, 20:17 »
Ok, I will have a think about whether I will or not. But what do you think about it not letting me delete video files?
« Reply #3 on: December 28, 2007, 20:19 »
Si.. a Picture tells a thousand words, plus loads more  ;)
Offline Moreno
« Reply #4 on: December 28, 2007, 20:28 »
haha thats brilliant cheers  :thumbs:
Do you know why it wouldn't let me delete?
« Reply #5 on: December 28, 2007, 20:56 »
The delete problem could be that the file is still in use somehow - have you tried it after a reboot?  Failing that, it could be a permissions setting, in which case, right click the file you want to delete, select Properties then the Security tab, and you should be able to edit the file's permissions in there.  Basically, you want it to be Full Control.
I expect Terry will be along soon with a video!  ;D
Offline Moreno
« Reply #6 on: December 28, 2007, 21:09 »
haha thanks...will give it a try!
« Reply #7 on: December 29, 2007, 11:12 »
Battery is flat Si..or else I would do a video  :blush:
« Reply #8 on: December 29, 2007, 11:54 »
