Author Topic: Web icon set to be discontinued  (Read 1050 times)
« on: December 28, 2007, 22:31 »
The browser that helped kick-start the commercial web is to cease development because of lack of users.
Netscape Navigator, now owned by AOL, will no longer be supported after 1 February 2008, the company has said.
FULL STORY
Re: Web icon set to be discontinued
« Reply #1 on: December 28, 2007, 23:36 »
That's a shame, because Netscape 9 is actually quite good, and I use it on my laptop.  :(
« Reply #2 on: December 29, 2007, 00:27 »
I bought Netscape, on a set of floppies, all those years ago. A sad day.  :cry:
« Reply #3 on: December 29, 2007, 00:29 »
Unless, like Mozilla, someone else takes it on.  :)
« Reply #4 on: December 29, 2007, 00:32 »
Another open-source browser. I can't see it, can you?
« Reply #5 on: December 29, 2007, 00:33 »
Probably not, so I guess it will be back to Firefox, seeing as Sea Monkey doesn't like my laptop for some reason.
« Reply #6 on: December 29, 2007, 00:41 »
Vista issue or more than that?
« Reply #7 on: December 29, 2007, 11:50 »
It is a Vista issue, but indirectly, and I don't know the cause.  One of the add-ons which is essential to me is the Home button (I say essential, OK, it's not life and death, but I would seriously miss it if it wasn't there), and the installation of this seems to somehow conflict with Roboform, as once installed, Roboform won't work, I get a blank, but unremovable, toolbar, and I get an error message every time I open or close Sea Monkey, to the effect of the Roboform adapter isn't compatible with my version of SM.  Well, they are both the latest versions and it all works fine on my XP machine, so I can only assume that something along the line isn't Vista compatible, and it seems to be the Home button add-on.
« Reply #8 on: December 29, 2007, 12:41 »
Well, you know the answer...  :devil:
« Reply #9 on: December 29, 2007, 12:52 »
There are several answers, but the easiest is to use Firefox instead.  :)
