April 11, 2025, 17:29
Technical Help & Discussion
Spellchecker Outlook express is in French
Topic: Spellchecker Outlook express is in French (Read 6476 times)
December 30, 2007, 12:14 »
Soooooo. The spellchecker on my Outlook Express is in French and therefore doesn't recognise any English words at all until I add them.
I thought it would be a simple fix via the options menu but there is no alternative language available.
Re: Spellchecker Outlook express is in French
December 30, 2007, 12:15 »
Have you checked your regional settings in Control Panel?
December 30, 2007, 12:44 »
Good point Rik. But they are set to English!
December 30, 2007, 12:56 »
Where did this computer come from, Clive? Does it small of garlic and onions?
But seriously, it seems that this is due to Office 2007 removing the English dictionaries from OE6. How helpful is that! The recommended solution is to download a third party spell checker for OE.
http://support.microsoft.com/kb/932974
December 30, 2007, 13:18 »
You've got to love Microsoft. Maintaining backward compatibility with the 8086 chip, but not with their own software.
December 30, 2007, 16:30 »
That is incredible! Yes, I have Office 2007 installed so it all makes sense now. What a bunch of half wits they are! Thanks very much Simon. This forum has been worth its weight in gold since I changed computers!
December 30, 2007, 17:14 »
It's what we do, Clive!
Or try to!
December 30, 2007, 23:16 »
Unfortunately I can't find a compatible spell checker. Those that are available are for old versions of OE and promptly crash OE6. This is a real retrograde step isn't it?
December 30, 2007, 23:35 »
If you have Office 2007 installed, why not use Outlook, or give Thunderbird a try?
Sandra
Ultimate Member
Reply #9 on:
December 31, 2007, 00:21 »
Quote from: Clive on December 30, 2007, 12:14
Quand tu ecrit en francais il est tres bon n'est ce pas Clive
gmax
Established Member
Reply #10 on:
December 31, 2007, 01:12 »
Clive, I emailed you a spellchecker that works with OE6
Reply #11 on:
December 31, 2007, 03:40 »
Personally, I use a dictionary.
gmax
Established Member
Reply #12 on:
December 31, 2007, 04:12 »
Quote from: mistybear on December 31, 2007, 03:40
I would too, but i'm far too lazy
Reply #13 on:
December 31, 2007, 09:25 »
Je ne parle pas Francais Sandra!
Thank very much for that Gmax. The spellchecker turned up but for some strange reason the attachment is greyed out.
gmax
Established Member
Reply #14 on:
December 31, 2007, 10:03 »
Clive, try downloading it from here:
http://www.iespell.com/
