Author Topic: Samsung Syncmaster 940n kaput !  (Read 4191 times)
Offline TOFFEEMAN1878
« on: December 30, 2007, 13:47 »
My Monitor has been Dead since a power cut ,it has power to it but I,m not getting any image on screen any ideas ,I,m using an old crt at the moment,any ideas .....Jim
Offline gmax
Re: Samsung Syncmaster 940n kaput !
« Reply #1 on: December 30, 2007, 14:20 »
Looks like something has blown on the main board or the backlight inverter is dead, your electricity supplier should be liable if it went dead with a power cut.
Reading stories like that makes me glad i use an "UPS" unit. Probably not worth repairing with the low price of new ones now.
« Reply #2 on: December 30, 2007, 14:27 »
Hi Jim,
Would it be possible to try the monitor on another machine?
« Reply #3 on: December 30, 2007, 14:45 »
That's probably the only useful diagnostic at this point, Simon. :(
« Reply #4 on: December 30, 2007, 15:01 »
Thanks for the help guys ,tried on another pc still no joy looks like a new one is required,it was surge protected as well with one of those big Belkin surgemasters  funny thing is the missus monitor of the same make a 710v is ok ......Jim
« Reply #5 on: December 30, 2007, 15:18 »
Surge protection is often not enough when there's a big mains spike, as tends to happen with power cuts. I favour conditioning UPSs for that reason.  :( You may be able to claim from Belkin though...
« Reply #6 on: December 30, 2007, 16:34 »
Treat yourself to this one TM
https://www.overclockers.co.uk/showproduct.php?prodid=MO-054-SA
I got it from Santa and it's brilliant. :D
« Reply #7 on: December 30, 2007, 16:34 »
Same thing happened to me a few weeks back.    Belkin - 6 power cuts - Mrs Clive's machine knackered mine clinging on.  I ended up slinging both and getting 2 new ones.   :laugh:
« Reply #8 on: December 30, 2007, 17:09 »
And you've not had a day's peace since. ;)
« Reply #9 on: December 30, 2007, 17:53 »
i keep thinking of buying a ups, but never do - any recommendations?
« Reply #10 on: December 30, 2007, 18:33 »
APC, Unitek or Belkin are all good Sam, just go for an inline, or conditioning model, not a backup type. Misco have this 1200VA Belkin for £112, there's an 800VA unit for £98.
Quidco gets you an extra 5% discount.
« Reply #11 on: December 30, 2007, 22:37 »
ooh thanks for info, I'll look into it...
Offline gmax
« Reply #12 on: December 31, 2007, 00:54 »
If you get one don't plug a laser printer into it, they draw too much current, ive been using the same APC UPS for 5 years now. I don't trust those surge protect boards.
You could get an UPS from ebay with dead batteries cheap, then replace the batteries yourself.
