Author Topic: Does USB Support 20 Meg?  (Read 3579 times)
Offline welshy.
« on: December 30, 2007, 21:58 »
For some reason I can't get my new mobo ethernet to work, so I'm using it via USB atm, but it doesn't download no where near what it should be, and it's on "10mbs"?
Re: Does USB Support 20 Meg?
« Reply #1 on: December 30, 2007, 22:35 »
what do you mean, "doesnt download no where near" - are talking speed or quantity?
Offline welshy.
« Reply #2 on: December 31, 2007, 17:07 »
Speed, i'm getting around 400k a sec, and i normally get 2300
Offline welshy.
« Reply #3 on: December 31, 2007, 17:15 »
And by saying the connection is on 10 i mean this.
Normally it's 100?
Offline welshy.
« Reply #4 on: January 01, 2008, 14:42 »
Anyonnnnnnne?  :-\
« Reply #5 on: January 01, 2008, 15:31 »
Sorry, I'm not really sure what the question is. Are you saying that you're using a USB modem rather than a router? If so, you may well find that your line speed has dropped, and with it your profile. Can you extract some line stats?
If that's not what you're saying, could you explain exactly what you are doing?
Offline welshy.
« Reply #6 on: January 01, 2008, 16:27 »
That i'm connected via usb not ethernet, and my speeds gone right down
« Reply #7 on: January 01, 2008, 16:32 »
Connected to what, though?
Offline welshy.
« Reply #8 on: January 01, 2008, 17:09 »
ntl modem
« Reply #9 on: January 01, 2008, 17:13 »
Can you get line stats from that? The most likely cause of your speed issue is the modem, USB will support ADSL flat out.
Offline welshy.
« Reply #10 on: January 01, 2008, 17:40 »
The modem was fine on ethernet, usb is what killed the speed, what stats exactly?
« Reply #11 on: January 01, 2008, 18:18 »
Downstream sync speed, noise margin and attenuation. If you can, a BT speed test would also be handy: http://test.speedtester.bt.com:50301/
Could the modem be a USB 1.x device?
Offline welshy.
« Reply #12 on: January 01, 2008, 18:35 »
It's 2x. On statues it's saying 10 MBPS? it's normally 100 on Ethernet, is that whats causing it?
« Reply #13 on: January 02, 2008, 00:22 »
Sounds like its only a USB 1 modem.
That would limit it to 12mb max so 10mb would be about right.
Ethernet would give you 100mb.
Unless your internet connection is over 10mb you shouldnt notice any difference in downloading, surfing and emailing, only slower data transfers between any PCs that you have on your network but if you are using USB to your PC then I assume that you arent networked.
Offline welshy.
« Reply #14 on: January 02, 2008, 20:31 »
It's a USB 2 supported modem I'm sure as it's not old, and I'm on 20 meg  :dunno:
