November 20, 2025, 20:28
The Buzz
Sticking DVDs
Topic: Sticking DVDs (Read 3352 times)
Sticking DVDs
January 11, 2008, 14:14 »
I have a couple of DVD's that freeze during playback. I've carefully cleaned them with a lens cloth and that has improved the situation enormously. However, they still need more cleaning. What would you recommend I use?
Baz
Established Member
Re: Sticking DVDs
January 11, 2008, 14:17 »
do you mean they freeze for ages and stop playing or just for a few seconds then play again Clive.
If its just for a few seconds thats normal with some DVDs. its something to do with the dual layer.
Re: Sticking DVDs
January 11, 2008, 14:25 »
Are these DVDRs, Clive? Unfortunately, I have found the lifespan of some brands to be little more than a few plays before they start to deteriorate.
Re: Sticking DVDs
January 11, 2008, 16:12 »
Yes, they are DVDRs and are not dual layer. I can see marks on them which will almost certainly wipe off with a damp cloth or a spray. The lens cloth removed most of the marks allowing the DVDs to play to around 75% before starting to play up.
Re: Sticking DVDs
January 11, 2008, 21:16 »
I would guess it's the marks that are causing the freezing, Clive.
Re: Sticking DVDs
January 11, 2008, 22:44 »
So what should I clean them off with?
Re: Sticking DVDs
January 12, 2008, 00:07 »
I usually just breathe on them and rub them on my jumper! Failing that, a fine spray of water and a micro-fibre cloth might help.
If you can get them to play, I would consider backing them up with new copies, in case it is the disc degrading.
Re: Sticking DVDs
January 12, 2008, 10:11 »
I'm surprised I haven't been able to find a proprietary cleaner on the market. I think I'll try your water spray method on one of those free DVD's you get with newspapers before using it on the disc I want to preserve. The problem with taking a backup at this stage is that it freezes at exactly the same points. But if I can get it clean then I will take another backup.
Re: Sticking DVDs
January 12, 2008, 11:36 »
Does it stick when you play it on the PC, Clive? Some DVD players are more sensitive than others, and if you find it plays on the PC, you should then be able to make backups on a good quality DVDR.
Re: Sticking DVDs
Reply #9 on:
January 12, 2008, 12:56 »
Unfortunately yes. I tried using Nero's repair tool but that failed. It's definitely the marks causing the problem and I think I'll try a damp cloth.
gmax
Established Member
Re: Sticking DVDs
Reply #10 on:
January 12, 2008, 13:01 »
Clive , copy the dvd's , use decent dvd's like "Tayio yuden" , they don't deteriorate like other brand dvd's.
Re: Sticking DVDs
Reply #11 on:
January 12, 2008, 13:10 »
I'm not familiar with that brand gmax, but I'm now using Memorex which I believe to be good. So far I have had no problems with them. The ones that are sticking are called Proformance - another make I've not heard of before!
Re: Sticking DVDs
Reply #12 on:
January 12, 2008, 13:26 »
I've found Verbatim to be very reliable, Clive (they were also my very first floppy disks, way back...). I also use Datasafe.
gmax
Established Member
Re: Sticking DVDs
Reply #13 on:
I made the mistake of buying cheap dvd's from ebay a couple of years ago, the dvd's deteriorated over time
, now i only use "Taiyo Yuden dvd's , no problems with these dvd's. This site is a good guide for buying dvd's ,
http://www.videohelp.com/dvdmedia
Re: Sticking DVDs
Reply #14 on:
January 12, 2008, 14:40 »
Thanks for the link gmax. I certainly won't buy cheapies again. I'm surprised at how badly my VHS tapes have deteriorated in recent years. Many are virtually unwatchable.
The Buzz
Sticking DVDs
