Author Topic: Motherboard that will support E8400  (Read 2691 times)
« on: January 12, 2008, 12:27 »
I have sort of decided to get an Intel E8400 CPU instead of a E6750, as they are around the same price.
But there seems to be a little confusion as to what motherboard will support these. The Gigabyte site states that the  GA-P35-DS3P (rev. 2.0) will support the 6 series CPU's but doesn't mention the 8 series. Is this because they weren't out when this was updated  (rev. 2.0) .
http://www.gigabyte.com.tw/Support/Motherboard/CPUSupport_Model.aspx?ProductID=2625
As the GA-P35-DS3P (rev. 2.1) does support the 8 series CPU's.
http://www.gigabyte.com.tw/Support/Motherboard/CPUSupport_Model.aspx?ProductID=2747
I know it states
Supports Intel® Core? 2 multi-core and upcoming 45nm processors
, but will the earlier versions support the 8400, or will it have out dated bios?
I couldn't even find a compatible board on the Intel site.......  :dunno:
http://processormatch.intel.com/CompDB/SearchResult.aspx?ProcNbr=E8400
I hope this makes sense.  :crazy:
Same goes for the Abit boards.
http://www.abit.com.tw/cpu-support-list/
http://www.abit.com.tw/cpu-support-list/intel/intel-core2-duo.htm
« Last Edit: January 12, 2008, 13:23 by mistybear »
Re: Motherboard that will support E8400
« Reply #1 on: January 12, 2008, 13:25 »
Theres a list of ASUS mobos here that says which support 45nano MB.
Look for the ones that do 1333 FSB and you may as well get one that will support quad core as no doubt Michael will want one of those sometime in the near future
http://event.asus.com/mb/45nm/
« Reply #2 on: January 12, 2008, 13:36 »
Thanks for that Sandra,   :thumbs: I was doing it the hard way.......  :P
Yes he probably will, I'm hoping he will be working by then.  ::)
What's the difference with a P35 Chipset and a G35 Chipset, I know that the G is more to do with
The Intel® G35 Express Chipset boosts your gaming and multimedia experience with the integrated graphics engine Intel® Graphics Media Accelerator X3500. It supports the latest 1333MHz FSB multi-core processors and platforms; and delivers breakthrough advances in 2D and 3D graphics and video capabilities. Featuring the Intel® Clear Video Technology, Enhanced Post-processing and Windows Vista compatibility, this chipset meets the changing display requirements of visually rich applications and provides smooth playback of High-Definition Videos, superb 3D effects and performance, crisp imaging, and accurate color control.
but does the this affect the CPU's performance, and in what way?
« Last Edit: January 12, 2008, 14:00 by mistybear »
« Reply #3 on: January 22, 2008, 01:02 »
Will his old WD 250GB harddrive from the 8383 be compatible as well as his Pioneer DVD RW and DVD ROM?
« Reply #4 on: January 22, 2008, 01:21 »
They will be but you may find that you dont have enough IDE connectors.
Newer mobos only tend to have a single IDE channel so you can only connect 2 PATA IDE devices.
You can always add a PCI IDE controller board if you need to connect more IDE devices than your mobo supports directly, theyre quite cheap  :)
« Reply #5 on: January 22, 2008, 01:38 »
I can't figure out which card is which?
Any of these?
http://www.shopbot.com.au/c-86-0-0-1.html
And we are probably going with this board, but are waiting for the rev 2.1, but if it isn't soon will get the rev 2.0.
http://www.gigabyte.com.tw/Products/Motherboard/Products_Spec.aspx?ClassValue=Motherboard&ProductID=2631&ProductName=GA-P35C-DS3R
« Last Edit: January 22, 2008, 01:50 by mistybear »
« Reply #6 on: January 22, 2008, 03:24 »
http://www.sltech.com.au/shop/product_info.php?products_id=710
Thats the type of card you would possibly need if you had too many PATA IDE devices for the mobo.
That mobo has 1 x IDE connector and 8 x SATA 3Gb/s connectors
So you would need the card unless you ditched one of the CD/DVD writers and got a SATA one.
Offline Camstop
« Reply #7 on: January 22, 2008, 08:50 »
Is this the one you mean MB?
Gigabyte-GA-EP35-DS4/p1
« Reply #8 on: January 22, 2008, 09:36 »
Very nice board and a really good review, thanks Cam.  :thumbs:
But alas, no. Michael has done away with the thought of running 2 cards, thank goodness.
So we have been eyeing off the GA-P35C-DS3R (rev. 2.1). The DDR2/DDR3 support I thought was maybe a good idea for the future, if the price ever comes down.
Found a couple of places that sell them now so hopefully a lot more places will have by the end of the week. And they will be cheaper the DS4.  ;)  ;D
