April 19, 2025, 00:23
Technical Help & Discussion
Thunderbird question
Topic: Thunderbird question (Read 1152 times)
daveeb
Loyal Member
January 12, 2008, 18:56 »
One for Simon maybe
Is there a way to import old thunderbird e-mail messages into a fresh Thunderbird install (i've had to set up XP twice on different drives in 3 weeks due to dodgy Maxtor drives)....anyhow it's easy to import OE stuff but no obvious way of getting my more recent Tbird e-mails on. I'm guessing there will be an add on that does this but I don't really fancy it after trying the FEBE add-on to organise backing up everything. It just didn't work properly. I suppose I could copy the old e-mail files (.MSF files) to the existing mail directory but i'm concerned that might shaft the existing setup. Any thoughts
daveeb
Loyal Member
Re: Thunderbird question
January 12, 2008, 19:12 »
I've answered my own question by overwriting the new folders (from TB install today) with the old files....worked fine
January 12, 2008, 20:08 »
That's exactly the way to do it, Dave.
daveeb
Loyal Member
January 12, 2008, 21:16 »
The only problem is that i have 2 other smallish backups of (unique) thunderbird email. I don't know of a way to merge them with the rest. obviously if try the method above the files will overwrite. Its the only advantage I can see with OE which will happily merge multiple e-mail backups into a new account. It's not important just frustrating.
January 12, 2008, 21:31 »
A rather clumsy way might be to create a new account in Thunderbird, copy the back up emails into it, then resend them to the account you want them in.
daveeb
Loyal Member
January 12, 2008, 21:56 »
Cheers for the idea Simon. In the end my solution was to find a program that can browse OE and TB e-mail formats (mail navigator) and its free as well
Also saves the e-mail application having to open hundreds of e-mails every time its accessed.
