Author Topic: Re-installing Windows XP?  (Read 1457 times)
« on: January 13, 2008, 11:49 »
I'm not sure if I should put all of these questions in the thread about upgrading Michael's computer or not, anyway it's a software problem, (I think).
Can we re-install Windows XP from the Medion Operating System Installation CD, when we replace the MB and CPU? Assuming we need to that is?
Re: Re-installing Windows XP?
« Reply #1 on: January 13, 2008, 12:46 »
probably not - but its definitely worth a go before going out and getting another version
« Reply #2 on: January 13, 2008, 12:53 »
What Sam said, MB, it's almost certainly an OEM version, tied to the original hardware.
Offline gmax
« Reply #3 on: January 13, 2008, 12:55 »
If your "Windows XP" is "OEM" , you might have trouble once the OEM version is activated on a PC, it can never be legally transferred from it to another PC, even if the PC dies,That's why it is cheaper. I replaced the m/b on a PC then reloaded XP OEM but i could not activate it , rang Microsoft support they just said it was a different PC
& did not want to know about it, i ended up using modified version of XP. Thats the last time i will pay for anything from Microsoft.
« Reply #4 on: January 13, 2008, 13:20 »
Thanks guys, not the answer I was hoping for.  :(
I do have another question, and you will notice, if you haven't already, I have no idea how all this stuff works.  :blush:
What happens to all the stuff on his harddrives when they are hooked up to the, programs, operating systems and games???????  :dunno:
Offline gmax
« Reply #5 on: January 13, 2008, 13:32 »
Just do i windows repair install, it's reloading XP but all your data will be saved, you will need to install the drivers CD that came with your M/B.   Info here: http://www.overclockers.com/tips1155/index.asp
« Last Edit: January 13, 2008, 13:38 by gmax »
« Reply #6 on: January 13, 2008, 14:03 »
That looks very promising gmax, thanks.  :thumbs:
I also found this link on whirlpool and it has another link about XP.
http://blogs.zdnet.com/Bott/?p=166
http://blogs.zdnet.com/Bott/?p=339
If it makes sense to you, let me know, all it did was confuse me.  :-\
I'll do more reading in the morning.  :snooze:
