Author Topic: tvcatchup  (Read 1192 times)
Offline Camstop
tvcatchup
« on: January 17, 2008, 15:24 »
After using BBCi a couple of times i can see how online TV is gonna work for a lot of people.
Tvcatchup seems to be the best at the moment as you can...
  • Record shows
  • 2 month history
  • 12 of the most popular freeview channels so far
http://www.tvcatchup.com/
UK users only, although if you get a friend to set up a login it seems to work on foreign IPs
Re: tvcatchup
« Reply #1 on: January 17, 2008, 19:53 »
I'm having bother catching up with all the programmes I've recorded on skyplus never mind tvcatchup.  I have some that are nearly a year old.  :crazy:
