Author Topic: PC Upgrade  (Read 1594 times)
Offline Scotty_CFC
PC Upgrade
« on: January 19, 2008, 20:52 »
Hi all,
I have recently built a PC from scratch, however, when it comes to playing games, it isnt performing the way I expected. It is only slightly faster than what my old PC performed. I used to have:
XP Home
P4 2.4GHz
PC2100 400MHz 1GB RAM
AGP ATI 9600 512mb card
2 x 40GB HDD (IDE)
The PC I have now is:
XP Home
Core 2 Duo 2.66MHz E6750
PC6400 800MHz 2GB RAM
PCI-E x 16 ATI X1550 512mb card
1 x 300GB HDD NCQ (SATAII)
I am guessing it might be the graphics card, I am thinking of getting an Nvidia 8800 GT. But before spending £150 - £200, I want your opinion. I have over clocked my current graphics card with minor results. Any tips?
Many thanks for any suggestions
Scott
Re: PC Upgrade
« Reply #1 on: January 20, 2008, 01:03 »
Your old pc wasnt exactly a slow specification.
The main thing that you have imrpoved is the capacity to run multiple applications rather than improve the speed of a single one, I would have thought.
If overclocking your current GFX card has improved things then an 8800GT would probably improve it more but I am unsure by how much.
