Author Topic: Proxy server  (Read 4125 times)
Proxy server
« on: November 11, 2002, 21:43 »
Can anyone explain briefly what a proxy server is?  Alternatively, is there any way I can temporarily disable the built in firewall on my Vigor 2600 router?  A friend of mine is on webcam and whilst Zone Alarm allowed webcams, my built in router doesn't.
Re:Proxy server
« Reply #1 on: November 11, 2002, 21:49 »
This will save me some typing!   :)
Proxy Servers
Re:Proxy server
« Reply #2 on: November 11, 2002, 21:59 »
My head hurts now Rodders.  Maybe disabling my router firewall is easier.   ;D  ;D  ;D
Re:Proxy server
« Reply #3 on: November 12, 2002, 09:44 »
It's not so much a case of disabling the router Clive, its more a case of allowing the webcam to see through your router.
Which software are you using for the webcam? Once we know that, its just a matter of enabling the right ports in the firewall  :)
Re:Proxy server
« Reply #4 on: November 12, 2002, 11:18 »
It's just the Yahoo webcam Adept, so I don't use any special software to view.  When I try to view it just says I'm behind a firewall so it wont work and suggests I try a proxy server.
Re:Proxy server
« Reply #5 on: November 12, 2002, 12:56 »
Hi Clive,
According to this document you need to open up port 5100 on your router.
Maybe I ought to ring you to talk you through it?  :o ;)
Re:Proxy server
« Reply #6 on: November 12, 2002, 13:07 »
Oh that's great news Adept.  You are coming down to fit a CD rewriter at some stage so I think I'll wait until then.   ;D  There's no rush anyway and if I mess this router up I will get a sound thrashing from Mrs Clive.  ;D
