November 27, 2024, 20:34
Technical Help & Discussion
Software, Hardware & Website Recommendations
Ad Aware
Topic: Ad Aware (Read 2442 times)
Baz
Established Member
Ad Aware
January 21, 2008, 13:31 »
anyone using Ad-Aware SE.....if so did you know about this
http://www.lavasoftsupport.com/index.php?showtopic=15293
I had problems updating the file definitions recently and when I looked on their site found out its getting phased out for a newer version. Trouble is the new version doesn't get very good reviews so far. You can still update manually.
So for future reference does anyone have any recommendations for good programs in case I decide to ditch this one.
Re: Ad Aware
January 21, 2008, 14:23 »
The new version of AdAware is diabolical. It gives new meaning to the phrase "if it ain't broke don't fix it".
Spybot Search and DestroySpybot search and destroy
is very good but be sure to download it from the link because there are rogue websites with similar names.
Baz
Established Member
Re: Ad Aware
January 21, 2008, 14:29 »
Thanks Clive. I have Spybot already. used them both as sometimes one would miss something and the other would pick it up. Shame about Ad Aware
I guess you tried it then
Re: Ad Aware
January 21, 2008, 15:02 »
Sadly yes.
Re: Ad Aware
January 21, 2008, 16:16 »
I would recommend
SuperAntiSpyware
, which comes in free or Pro varieties.
Re: Ad Aware
January 21, 2008, 20:17 »
You can still happily continue to update your older version of Ad Aware by downloading the zipped
Definitions File
from AAW's website.
Simply unzip the "defs.ref" file into your main AAW folder, overwriting the existing file. Then repeat after me, "Bingo!"
Baz
Established Member
Re: Ad Aware
January 21, 2008, 21:30 »
thats right, had to do that. Thats how I found out about the latest version been crap. followed a few links and stumbled on that post in a forum.
Ad Aware
