Author Topic: How do I change the installation drive?  (Read 3583 times)
Offline Kaz
« on: February 06, 2008, 12:39 »
Hi everyone,
I am trying to install a exe file which I have downloded and I want to install it to My E drive, but it keeps installing it to my C drive which I don't want it is not giving me the option to choose which drive I install too, so is there another way I can install this to the drive of my choice please
Re: How do I change the installation drive?
« Reply #1 on: February 06, 2008, 15:35 »
If the installer is that bad-mannered, Kaz, I'd have doubts about using the program tbh.
Offline Kaz
« Reply #2 on: February 06, 2008, 17:31 »
It's UTorrent Rik,
it automatically updates, but I want to download a previous version and put it on a different drive  ':|
« Reply #3 on: February 06, 2008, 18:31 »
I'm not a torrent person, sorry, Kaz. :(
« Reply #4 on: February 06, 2008, 19:06 »
uTorrent doesn't actually install anywhere.  It runs from the .exe file, Kaz, so put the .exe file where you like, and create a short cut to it on your desktop.
Offline Kaz
« Reply #5 on: February 07, 2008, 07:47 »
Hi Simon,
well at the moment I have it installed in Programme files on my E drive where I installed it to you can choose where you want it to go, sorry but I have done this and now I want to install another version, but as you say it goes straight to my C Drive  :dunno:
« Reply #6 on: February 07, 2008, 09:47 »
Are you saying you want to update the version you already have, or want to completely reinstall it?  If you just want to update it, click Help > Check For Updates, and it will automatically update itself.  If you want to start again, just delete the uTorrent.exe file from wherever it is, and replace it with the newly downloaded version.
Offline Kaz
« Reply #7 on: February 08, 2008, 08:40 »
Ha yes this is where I have the problem when I install it this time it doesn't ask me where I would like to install it to and just as you say puts it well where ever it likes too I cant get it to install on my E drive it puts a short cut on my desktop, bu it doesn,t install to programme files so where Goes it go too? and I have 2 copies one on E drive and the other where ever? and I dont want to use the new updated version at the moment it's not too good and some sites have banned it! this version I have has an exe and then a installer with it if you download it off their web site it's just and exe file ':|
« Reply #8 on: February 08, 2008, 09:54 »
As I said, it doesn't install, Kaz, it runs direct from the .exe file, so whichever version you want to use, delete the other one, put the one you want where you want it, and create a desktop shortcut from there to run it.  :)
Offline Kaz
« Reply #9 on: February 08, 2008, 11:57 »
Thanks
Thanks Simon,
am I being Thick? Im still a little confused, how come I installed the version Iv got to where I want and how I want ? :dunno:
« Reply #10 on: February 08, 2008, 14:17 »
I'm only going by experience from my own set up, Kaz.  I haven't a clue what you did before, but check in your Add / Remove programs, and you shouldn't find uTorrent there, as it's not an installed program.  To put it where you want it, you just move the downloaded 'uTorrent.exe' to the location from where you want it to run, and for convenience, place a shortcut to it on your desktop.  I can't really explain it any clearer, as there's nothing else to explain!  :)
Offline Delgado
« Reply #11 on: February 09, 2008, 08:07 »
Sorry to disagree Simon, but the later versions of uTorrent do install, this has been the case for a few versions.
 Ive just checked my installed progs and its shown there quite clearly.
« Reply #12 on: February 09, 2008, 09:51 »
Well, it definitely isn't on mine, and I have the latest version, as it updated only the other day.
If that's the case, then I have to apologise, Kaz for giving you wrong information.
I'll get me coat...
Offline Delgado
« Reply #13 on: February 09, 2008, 10:20 »
Hi Simon
 My version is 1.7.7
 Im not sure, but Ive got a feeling that there is an option to have either an installer when you download or just an exe file. Will check on site.
Offline Delgado
« Reply #14 on: February 09, 2008, 10:26 »
Cant see any info on site-as soon as you click downloads you dont get the option that I suspect you used to get.
Are you useing Vista Simon-maybe thats why?
