That question depends upon what you want to use your system for ... if you want the ability to copy from a CD to another CD, then I would go for seperate drives ... the "combo" is ideal for saving space, but means you have to save files to your hard drive before copying to CD
A "combo" also has the ability to free up an IDE channel, if you need them for other things like extra hard drives.
