Author Topic: Mousepad problem  (Read 1468 times)
Mousepad problem
« on: February 14, 2008, 21:51 »
On my Acer laptop, the mousepad and buttons work, but since I turned it on this evening, the up, down, left, right scrolling thingy in between the left and right buttons has stopped working.  This is really annoying!  I'm wondering if Windows Updates have done something?  Any ideas?
Re: Mousepad problem
« Reply #1 on: February 14, 2008, 22:33 »
Why don't you try doing a system restore to see if it really is the updates causing the problem?  If not you can always download them again.
« Reply #2 on: February 14, 2008, 22:50 »
I've just solved it by reinstalling the drivers.  Must have been something to do with WU.   ':|
