Author Topic: Curser jumps around  (Read 1513 times)
Offline renshaw8
Curser jumps around
« on: February 18, 2008, 22:53 »
I have a Toshiba Satellite laptop with Windows XP (Media Edition) and for the last week my curser has periodically jumped somewhere else on the window. I have a Logitech optical mouse and tried a new driver from the Logitech website but it still moves around sometimes. I'd appreciate any help if somone would know what this problem might be. Thanks!
f you watch the penny's, the dollars will watch themselfs.
Re: Curser jumps around
« Reply #1 on: February 18, 2008, 23:17 »
Could it be your mousepad playing up?  Have you tried reinstalling the drivers for that?  Have you scanned for viruses / spyware, etc?
Offline renshaw8
« Reply #2 on: February 19, 2008, 01:54 »
 Thanks Simon,....I'm not sure about installing. I downloaded a recommended driver and the Logitech website said that it would install the new driver after downloading it and clicking on it...............I have a cd that came with the mouse but never used it because the mouse worked good ever since I first plugged in the mouse a year ago.
« Reply #3 on: February 19, 2008, 09:18 »
Well, it's possible that the mouse itself is on the way out.  Do you have another one, or could you borrow one you could try?
« Reply #4 on: February 19, 2008, 11:07 »
I had a similar problem with a logitech mouse.
I uninstalled the driver and also scanned pc and deleted anything to do with logitech.
I then installed from the disc that came with the mouse and all worked fine.
Sometimes these drivers you download from logitech screw things up.  Better to stick to the software that came with the mouse.
Offline renshaw8
« Reply #5 on: February 20, 2008, 23:06 »
Thanks Simon, I have another mouse that I just thought about trying.....but first..... Lona, I'm going to try what you said. Please reply back and tell me how to uninstall my logitech driver. Thank you.
« Reply #6 on: February 21, 2008, 08:18 »
Go into Control Panel, then Add and remove programs to see if you can locate the Logitech software there.  But I have always found that installing a new driver over the old one usually does the trick anyway.
Offline renshaw8
« Reply #7 on: February 22, 2008, 15:48 »
 Thanks Lona, I guess I'm ready to try fixing it........I'll post results
