Author Topic: Nero?  (Read 2948 times)
Offline Michelle
    • Techieminx
Nero?
« on: March 07, 2008, 19:05 »
Okay I know I am so useless at this and probably asked before (so i am sorry if so) but can you please tell me if I can use nero to copy a homemade dvd-r to cd-r (the files on the dvd-r are listed as audio ts and video ts) I thought I had worked out how to do it but it keeps coming up with an error.  ???
Re: Nero?
« Reply #1 on: March 07, 2008, 19:29 »
Will the files on the DVD fit on a CD, Michelle?  Don't forget, CDs have much less storage capacity than a DVD.
Offline Michelle
    • Techieminx
Re: Nero?
« Reply #2 on: March 07, 2008, 19:36 »
There's a point, I'll check -thanks
Offline Michelle
    • Techieminx
Re: Nero?
« Reply #3 on: March 07, 2008, 19:39 »
oh poo lol no its 4.3 gbs!
thanks for pointing that out..... I'd have been trying to do it for ages lol ... ok now I need to find a blank dvd ... but okay I still need to know how to do that please, cos I've not got past the copying stages yet.
Re: Nero?
« Reply #4 on: March 07, 2008, 20:34 »
If you have the correct media, it should just be a straightforward DVD Copy, Michelle.  :)
Re: Nero?
« Reply #5 on: March 08, 2008, 00:00 »
When in Nero, Michelle, you only have to drag over the VideoTS folder from the disc you are copying from and then hit burn.  Make sure it's a dvd video you select and not a dvd iso
Offline Michelle
    • Techieminx
Re: Nero?
« Reply #6 on: March 08, 2008, 14:50 »
oh yes I see Lona, thanks alot :) So I was doing the right thing its just that the cd was no good lol duh!  ::)
ok I must have some blank dvd's here somewhere! haha
Re: Nero?
« Reply #7 on: March 08, 2008, 16:31 »
I've got plenty of spares, Michelle. :)
Offline Michelle
    • Techieminx
Re: Nero?
« Reply #8 on: March 12, 2008, 18:30 »
i found one thanks lol - but i still can't do it, it says - this cd is read only - and I cannot copy it, so is that it? Or do you think I am doing something wrong?  :dunno:
Re: Nero?
« Reply #9 on: March 12, 2008, 19:01 »
All CDs are read-only. I take it it is referring to the source CD? Possibly it's got some form of copy protection on it. IAC, weren't you copying a DVD?  ???
Offline Michelle
    • Techieminx
Re: Nero?
« Reply #10 on: March 13, 2008, 22:11 »
yeah i was copying a dvd ... hmmm ... I did wonder if it had some protection, I just don't know, maybe I'll try again.
Re: Nero?
« Reply #11 on: March 13, 2008, 23:54 »
If it's a home made DVD-R, it shouldn't have any copy protection on it, Michelle.  Just open Nero SmartStart, and select Copy DVD.  It should be straightforward from then on.  :)
Offline Michelle
    • Techieminx
Re: Nero?
« Reply #12 on: March 14, 2008, 16:57 »
ah ok thanks simon I'll try that way - well I've done that and it said save image file so I did that now it says its writing to disc...... what do I do next, when thats done?  :blush:
Re: Nero?
« Reply #13 on: March 14, 2008, 18:49 »
Try the new disc to see if you can read it OK.
Offline Michelle
    • Techieminx
Re: Nero?
« Reply #14 on: March 14, 2008, 22:09 »
Disc was empty.... so I found something that said burn image to disc, so i did that and it got stuck at 80% ?  ::)
