Author Topic: A few minor failures.......  (Read 1486 times)
« on: April 01, 2008, 11:59 »
Re: A few minor failures.......
« Reply #1 on: April 01, 2008, 12:04 »
some look quite painful.. others look very faked... http://ajanlo.kapu.hu/fail/fail_12.jpg for example.
« Reply #2 on: April 01, 2008, 12:06 »
« Reply #3 on: April 01, 2008, 12:10 »
I've seen number 12 before and thought it was real, why do you say it's faked, Sam?
28 is just true...... :(
« Reply #4 on: April 01, 2008, 13:53 »
Very enjoyable!   :laugh:
« Reply #5 on: April 01, 2008, 14:00 »
well its the last one in the sequence that I doubt, not the rest, it just looks like the green truck has been rotated from its "sitting" position..
« Reply #6 on: April 01, 2008, 14:51 »
I think the weight of the first crane, it was trying to lift, just pulled it that far, as it sank to the bottom. Plus you don't know how long after it toppled over that the photo was taken.
Online Simon
« Reply #7 on: April 01, 2008, 16:27 »
The first one must have hurt!  ;D
« Reply #8 on: April 02, 2008, 08:10 »
I pity the owner of the car, as it's literally, at the bottom of all of this.  :)x
« Reply #9 on: April 02, 2008, 10:59 »
it just doesn't look real, I'm not saying it isn't it just looks too perfect.
« Reply #10 on: April 02, 2008, 11:06 »
You're such a cynic Sam.........  :laugh:
« Reply #11 on: April 02, 2008, 13:02 »
Hes not in regards to the moon landings for some reason though MB  ;D
« Reply #12 on: April 02, 2008, 13:51 »
Yes, odd that isn't it.  :dunno:
Perhaps he's seen the flag they left behind, through a telescope, that's the sort of proof I'd need.  ;D
« Reply #13 on: April 02, 2008, 15:19 »
to see the flags would be in feasible. Well if we had a satellite in extremely close orbit you might be able to.. and it would need decent cameras. I actually think one of the Indian missions / the JAXA mission is aiming to fly over the site and its camera are of a similar resolution to the landing sites.. so we should expect to see some remnants. I'm pretty sure the only way we will see the flag so clearly again would be to go back to the exact site...
