Author Topic: Update.exe can't update  (Read 1486 times)
« on: April 14, 2008, 08:58 »
Since the repair, re-install of XP, it can't update the missing hotfixes. (87 missing)
When I first turn the computer on the update.exe runs using about 50% CPU trying to install the missing hotfixes, but fails, this is what it does download.
[KB896358.log]
0.703: ================================================================================
0.703: 2008/04/14 17:02:49.078 (local)
0.703: C:\WINDOWS\SoftwareDistribution\Download\a30fe106c075193a6848a7f64073a7cc\update\update.exe (version 6.1.22.4)
0.703: Hotfix started with following command line: /si /ParentInfo:daaf64c80508fd4f84e739a420e40daf
0.938: DoInstallation: CleanPFR failed: 0x2
0.938: SetProductTypes: InfProductBuildType=BuildType.IC
0.938: SetAltOsLoaderPath: No section uses DirId 65701; done.
0.969: CreateUninstall = 1,Directory = C:\WINDOWS\$NtUninstallKB896358$
0.969: LoadFileQueues: UpdSpGetSourceFileLocation for halmacpi.dll failed: 0xe0000102
0.985: ref tag c:\windows\system32\sp4.cab does not exist
0.985: ref tag c:\windows\system32\sp3.cab does not exist
0.985: ref tag c:\windows\system32\sp2.cab does not exist
0.985: ref tag c:\windows\system32\sp1.cab does not exist
0.985: ref tag c:\windows\system32\driver.cab does not exist
0.985: ref tag c:\windows\system32\fp40ext.cab does not exist
0.985: ref tag c:\windows\system32\fp40ext1.cab does not exist
0.985: ref tag c:\windows\system32\wms4.cab does not exist
0.985: ref tag c:\windows\system32\wms41.cab does not exist
0.985: ref tag c:\windows\system32\ims.cab does not exist
0.985: ref tag c:\windows\system32\ims1.cab does not exist
0.985: ref tag c:\windows\system32\ins.cab does not exist
0.985: ref tag c:\windows\system32\ins1.cab does not exist
0.985: Starting AnalyzeComponents
0.985: AnalyzePhaseZero used 0 ticks
0.985: No c:\windows\INF\updtblk.inf file.
0.985: OEM file scan used 0 ticks
1.266: AnalyzePhaseOne: used 281 ticks
1.266: AnalyzeComponents: Hotpatch analysis disabled; skipping.
1.266: AnalyzeComponents: Hotpatching is disabled.
1.266: FindFirstFile c:\windows\$hf_mig$\*.*
1.391: KB896358 Setup encountered an error:  The  update.ver file is not correct.
1.422: KB896358 Setup encountered an error:  The  update.ver file is not correct.
1.469: KB896358 Setup encountered an error:  The  update.ver file is not correct.
1.485: KB896358 Setup encountered an error:  The  update.ver file is not correct.
1.500: KB896358 Setup encountered an error:  The  update.ver file is not correct.
1.516: KB896358 Setup encountered an error:  The  update.ver file is not correct.
1.547: AnalyzeForBranching used 31 ticks.
1.610: AnalyzePhaseTwo used 63 ticks
1.610: AnalyzePhaseThree used 0 ticks
1.610: AnalyzePhaseFive used 0 ticks
1.610: AnalyzePhaseSix used 0 ticks
1.610: AnalyzeComponents used 625 ticks
1.610: Downloading 0 files
1.610: bPatchMode = TRUE
1.610: Inventory complete: ReturnStatus=0, 641 ticks
1.610: Num Ticks for invent : 641
1.610: [dumpDownloadTask] We have all necessary files for the package to install. Return STATUS_READY_TO_INSTALL
1.610: dumpDownloadTask returned 0xf201 (ready to install)
1.625: KB896358 installation did not complete.
1.625: Update.exe extended error code = 0xf201
Re: Update.exe can't update
« Reply #1 on: April 14, 2008, 11:38 »
Problem solved, it is a Microsoft issue.
http://support.microsoft.com/kb/943144
« Reply #2 on: April 14, 2008, 11:56 »
Well done for finding the solution MB  :)
I think we should award you 10 techie points for that  :)
« Reply #3 on: April 14, 2008, 12:01 »
Can't Sandra, I pinched it from Gary on Rik's forum, idnetters, you don't think I'm that smart do you.  :)x
http://www.idnetters.co.uk/forums/index.php?topic=7561.0
