Author Topic: help if router  (Read 2318 times)
Offline GSS
    • artzone4u.com
help if router
« on: May 01, 2008, 22:04 »
ok here i go
i got a new belkin THat is
http://www.argos.co.uk/static/Product/partNumber/6754257/Trail/searchtext%3EROUTER.htm
now where i need help is my nat is set to moderate on my xbox live but i need to set it to open
i think i need to open some ports  on the router but i do not know how
i need to open
UDP 88
UDP 53
UDP 3330
UDP 3074
TCP 3074
www.artzone4u.com
banner coming soon
Online Simon
Re: help if router
« Reply #1 on: May 01, 2008, 22:16 »
Do you know how to get into the router set up?  Open a browser window in IE or Firefox and type in 192.168.2.1, hit enter and you should be required to put in your user name and password to access the router set up.  Once you're there, you'll need to set firewall rules to open the ports you need, but as I don't have a Belkin, I can't help you with that, but it should be fairly straightforward.
Offline GSS
    • artzone4u.com
Re: help if router
« Reply #2 on: May 01, 2008, 22:24 »
yes i can get in to the setup but when i get in there i do not know how to open ports
www.artzone4u.com
banner coming soon
Offline gmax
Re: help if router
« Reply #3 on: May 02, 2008, 05:31 »
Offline GSS
    • artzone4u.com
Re: help if router
« Reply #4 on: May 02, 2008, 09:13 »
ok thank you gmax i just have to phone xbox now has the ports there give me do not work :dunno:
www.artzone4u.com
banner coming soon
Online Simon
Re: help if router
« Reply #5 on: May 02, 2008, 09:36 »
Have you also got a software firewall?  You may have to open the same ports in that too.
Offline GSS
    • artzone4u.com
Re: help if router
« Reply #6 on: May 02, 2008, 15:20 »
thank you Simon did not think of at and yes i got Kaspersky Internet Security 7.0
www.artzone4u.com
banner coming soon
