Author Topic: Firefox crashing  (Read 3432 times)
Firefox crashing
« on: May 13, 2008, 13:31 »
I'm having problems with Firefox. It keeps shutting down.
I'm using version 2.14 and have looked on Mozilla site for a solution.
Only thing I can find is something to do with Java and it advises uninstalling Java.
I really don't want to do this. Does anybody else have this problem
Re: Firefox crashing
« Reply #1 on: May 13, 2008, 13:51 »
What add-ons do you have, Lona?  It could be one of them, not FF itself which is crashing.  Also, have you tried reinstalling the Java plug in?
« Reply #2 on: May 13, 2008, 14:06 »
I'm using the same version, Lona, with no problems. I agree with Simon, start with the addons. If it's not them, then look at your security software.
« Reply #3 on: May 13, 2008, 16:24 »
I've got the java plugin so it can't be that.
I've got avg safe search, I wonder if that's the problem.  This has only started since I updated to avg version 8
« Reply #4 on: May 13, 2008, 16:28 »
All you can do is try turning off AVG safe search, and see if it helps, Lona.  Is that some sort of anti-phishing tool?
« Reply #5 on: May 13, 2008, 16:29 »
Dunno, Simon.  I only saw it when I went into firefox to check my addons. I'll go and investigate
« Reply #6 on: May 13, 2008, 16:33 »
Found a setting on avg called "link scan" so I've disabled it.  Will see how it goes in the next few hours
« Reply #7 on: May 13, 2008, 16:38 »
OK, let us know how it goes, Lona.
« Reply #8 on: May 13, 2008, 16:57 »
I've also had one or two problems lately with Firefox, nothing terribly spectacular until just now when I followed a link to an eBay sale.  It keeps re-loading the page and other open tabs stutter.  Like Lona, I've got the AVG add-on.  I've just disabled it and I'll see how I get on now.
