Author Topic: Thunderbird question  (Read 1267 times)
« on: May 17, 2008, 18:49 »
One for Simon I think  ;) How do I get Tbird to import multiple e-mail backups i.e. i have the tbird folders from three different periods of time.  I want to import them all into my latest install.  Is it just a case of renaming the folders (otherwise they'll overwrite each other) and copy them to the tbird folder ? thankee
Re: Thunderbird question
« Reply #1 on: May 17, 2008, 21:14 »
Hi Dave,
I'm trying to think how to do this, because usually, whenever I have reinstalled TB, I have just imported the mail from the previous version straight away, so the folders are overwritten, but nothing is lost, if you follow me.  How did you come to have three separate profiles?  Anyway, I don't think renaming the folders would work, as then it wouldn't associate your account with the mail folder.  I can think of a number of ways to do this:
If you created a couple of new 'false' mail accounts, which don't actually do anything, then you could copy the new mail folders with the old ones, but that seems a bit messy.
You could open the old folders, and rename the files within them (i.e, Inbox2, Sent2, etc for one, and Inbox3, Sent3, etc for the other), then when you copied them to the TB mail folder, it should create separate Inboxes for the old mail.  Again, a little untidy.
Alternatively, you could try this: http://nic-nac-project.de/~kaosmos/mboximport-en.html.  The write up seems complicated, but I have just tried it out, and it seems fairly straightforward.  There is an option to overwrite existing mail, but this is unticked by default, so hopefully it won't, but I would strongly advise you to back up your current mail folders first, just in case, then at least, if this doesn't work, you won't have lost anything.  I still think it will create an additional folder in your mail account, but I can't think of a way to 'merge' your mail folders in the way you would like.
Oh, one more thing you might want to look at is: http://www.mailstore.com/en/mailstore-home.aspx
Hope that helps, Dave.  There may, of course, be a much simpler way I haven't thought of.  :-\
« Last Edit: May 17, 2008, 21:16 by Simon »
« Reply #2 on: May 17, 2008, 21:47 »
Thanks for the info and links Simon  ;) The reason i have so many different backups is due to the insane number of drive/OS failures i've had in the last 6 months, but at least i'd backed everything up regularly so not much was lost. I really don't mind if seperate inbox folders are created, but it's a shame TB can't just merge all the different info like OE can  :woot: (not that i'd ever revisit OE).  my alternative is a program called mail navigator which can open various formats of mail and even save each e-mail as an individual file.  It's very clunky but free!! Anyhow i'll have a look at mboximport and cheers again  ;D
« Reply #3 on: May 18, 2008, 14:13 »
if it put it into three different inboxes you could then just copy them over into just the one, should be a simple drag and drop procedure.
« Reply #4 on: May 18, 2008, 15:17 »
But that would be far too easy, Sam.  ;)
