Author Topic: Avg Question  (Read 1659 times)
Offline welshy.
Avg Question
« on: June 02, 2008, 17:41 »
Helllllo again  ;) Quick question, before i formatted when i searched for something for instance in google, AVG would check the links and put a tick by the side of them to say if there safe or not, anyway i formatted which was needed and reinstalled AVG the same version and now that features gone, anyone know what it's called?
Re: Avg Question
« Reply #1 on: June 02, 2008, 18:24 »
Only AVG 8 is being supported these days Welshy.  If you have an earlier version you won't receive any more updates and certain features may no longer work.
Offline welshy.
Re: Avg Question
« Reply #2 on: June 02, 2008, 18:37 »
I've got 8.0.10 same version as i had prior to format, just the feature seems to be off now  >:(
Re: Avg Question
« Reply #3 on: June 02, 2008, 19:21 »
Welshy..have you ticked the box  :)
Offline welshy.
Re: Avg Question
« Reply #4 on: June 02, 2008, 19:30 »
Yup, even unticked and reticked to check  :(
Offline welshy.
Re: Avg Question
« Reply #5 on: June 02, 2008, 20:02 »
A reinstall solved the problem! Maybe it was because i installed firefox after avg  :dunno:
Re: Avg Question
« Reply #6 on: June 02, 2008, 20:44 »
 :solved:  Thanks for letting us know Welshy!
Re: Avg Question
« Reply #7 on: June 02, 2008, 20:46 »
Isn't it great when members solve their own problems!  Makes our job so much easier.   ;D
