Author Topic: Timed startup programs?  (Read 1764 times)
« on: June 03, 2008, 12:18 »
Is it possible, or does anyone know of a utility, to control the starting order of startup programs?  All I want is to have my calender as the last thing to start, so that any reminder windows appear on top of other windows, and I don't miss them.
Re: Timed startup programs?
« Reply #1 on: June 03, 2008, 15:57 »
Could you select 'always on top' in its properties?
« Reply #2 on: June 03, 2008, 17:05 »
Take a look at THIS Simon.
« Reply #3 on: June 03, 2008, 20:57 »
I might be being thick, but I don't see how, Rik.  :dunno:
Excellent find, thanks Clive, I think that will do just the job.  :thumb:
« Reply #4 on: June 04, 2008, 11:31 »
Some apps have the ability to select an 'always on top' option, so they will always be visible.
« Reply #5 on: June 04, 2008, 12:14 »
I don't think Sunbird does, Rik, but Clive's app works a treat, once I'd persuaded F-Secure to allow it.  Curiously, it installed on my Vista machine with no challenges from F-Secure at all.
« Reply #6 on: June 04, 2008, 12:44 »
That's Vista for you. :)
« Reply #7 on: June 04, 2008, 22:22 »
Not sure whether to take that as good or bad, Rik!  ;)
« Reply #8 on: June 05, 2008, 11:52 »
That's Vista for you.  ;D ;D
