Author Topic: Not able to connect  (Read 1844 times)
Offline nilsatis
Not able to connect
« on: June 03, 2008, 18:42 »
Hi all,
My mate cannot conect to the internet, she is getting error code 678 any ideas (idiot guide please)
Andy
Re: Not able to connect
« Reply #1 on: June 03, 2008, 19:29 »
Is she using a USB modem?
Offline nilsatis
« Reply #2 on: June 03, 2008, 21:44 »
yes i just went to have a look its saying that the modem isnt connected, the light on the modem is flashing, and showing that a network cable isnt connected
« Reply #3 on: June 03, 2008, 21:59 »
So, this is a USB modem, which connects each time the PC is powered on, yes?  To start with the obvious, have you actually checked that all the cables are connected correctly?
Offline nilsatis
« Reply #4 on: June 03, 2008, 22:02 »
Yea checked the cables they all are connected
Offline Camstop
« Reply #5 on: June 03, 2008, 22:05 »
Try pulling the power plug out of the back of the modem and leaving it out for 1 minute, then plug it back in and see if i boots back up properly.
Offline nilsatis
« Reply #6 on: June 03, 2008, 22:19 »
yep tried all of the basic stuff, its just saying network cable not connected and light stays flashing
« Reply #7 on: June 03, 2008, 22:52 »
Sorry, Andy, but can you just confirm that this is a USB ADSL Modem, and not a router?  I'm wondering if it's trying to connect to a LAN which doesn't exist.  Can I suggest she goes into Internet Explorer > Tools > Internet Options > Connections and check that the correct connection (her ISP) is set as default, and that the 'Always dial my default connection' button is selected?
« Reply #8 on: June 04, 2008, 11:33 »
The flashing light usually means it's not achieving sync. Try disconnecting everything but the modem from the phone circuit.
Offline nilsatis
« Reply #9 on: June 06, 2008, 08:34 »
Thjanks for the repies, she got home last night turned her pc on and it was all working again!!!    ???
« Reply #10 on: June 06, 2008, 09:38 »
Oh well, maybe it just needed a reboot.  :dunno:  Glad it's all OK now, Andy.  :)
