Author Topic: media player  (Read 1469 times)
Offline nilsatis
media player
« on: June 07, 2008, 13:05 »
Hi all,
Im on windows vista and my media player appears to have a glitch it jumps and stutters on every single music track just before the end, any ideas???
Andy
Re: media player
« Reply #1 on: June 07, 2008, 13:14 »
Hi Andy,
Is this Windows Media Player, and have you got the latest version?  You could try another media player, such as WinAmp to see if you get the same problem.
Offline nilsatis
Re: media player
« Reply #2 on: June 07, 2008, 13:20 »
Simon, yea its windows, i will try winamp
Re: media player
« Reply #3 on: June 07, 2008, 13:22 »
Also, is this just music files, or does it happen when playing CDs?
Re: media player
« Reply #4 on: June 07, 2008, 13:26 »
Found this, Andy:
Control Panel
Click Sound
Select Playback tab
Select Speakers/Headphones entry
Click Properties
Select Enhancements Tab
Disable all enhancements
Watch Media player perform 100 times faster with no stutter
http://forums.techguy.org/multimedia/584818-windows-media-player-11-stuttering.html
Offline nilsatis
Re: media player
« Reply #5 on: June 07, 2008, 14:31 »
Cheers Simon, that worked a treat, I downloaded winamp anyway, it sounds better.   :thumbs:
Re: media player
« Reply #6 on: June 07, 2008, 17:20 »
Glad to help.  :)
