Author Topic: Anyone know what this is?  (Read 2397 times)
« on: March 16, 2003, 11:15 »
Application NT Kernel & System (ntoskrnl.exe)[/color] keeps being blocked by my Firewall, and I get a pop up alert.  Does anyone know what this is, and what it might be trying to do?  I would imagime it's something to do with Windows NT, but seems odd as I'm using XP, although I realise they are similar.
I recently switched from Norton 2003 to Sygate Pro Firewall, and I have been getting the alerts since then.
Edit: Should have said, this is an incoming TCP from various IP addresses that is being blocked.  A Whois doesn't give much away.
Re:Anyone know what this is?
« Reply #1 on: March 16, 2003, 11:30 »
NTOSKRNL.EXE is a core part of Windows XP/2000/NT.
You should always allow it through your firewall. But also wake sure that it is regularly scanned for viruses/trojans as it is a popular file for attack!
« Reply #3 on: March 16, 2003, 11:45 »
Thanks Sean, I'll have to take some time to read all that later.
Can you just confirm I should allow INBOUND traffic to this NTOSKRNL.EXE, as that's what it seems to be blocking.
« Reply #4 on: March 16, 2003, 11:49 »
I'm honestly not sure Simon :-X I would leave it as it is for the moment.
There are some more documents on the Sygate site regarding this. It's probably best to read them all before making a descision.
« Reply #5 on: March 16, 2003, 11:58 »
OK, thanks
