Author Topic: Upgrading Graphics Card ??  (Read 2185 times)
Offline TOFFEEMAN1878
« on: June 17, 2008, 14:47 »
I have a Asus M2N-SLI Deluxe M/B ,Ge Force 6200 Turbo Cache(TM) & a  2232 BW Samsung Syncmaster monitor ,I want to change the GC to a Ge Force 8800GTS ,But this card has dual DVI outputs ,The problem is I don't get a signal when using the DVI connection any ideas ?.....Jim
Re: Upgrading Graphics Card ??
« Reply #1 on: June 17, 2008, 21:05 »
Hi Jim, sorry no one's responded to your question yet.   :(
I found something elsewhere which may be of some use:
"Most monitors that have DVI inputs use DVI-D signaling, or digital. If the DVI port on the card is a DVI-A (A for Ananlog) then it won't run the display. A DVI-I port does both. If you have a display with an analong (blue) cord then you can pop a DVI-VGA adapter onto the DVI port and see if it works. if it does then the DVI ports are analog or possibly DVI-I."
Also, have you looked in the Graphics Card settings to see if there's a switch to output the DVI signal?
That's all I can think of for now, but hopefully someone will be around later with some more ideas.
« Reply #2 on: June 17, 2008, 22:26 »
sorry which one do you not get the signal from, the existing one or the new one?
« Reply #3 on: June 18, 2008, 16:36 »
Sorted now guys ,had to manually change the settings in Display Properties  :blush:
« Reply #4 on: June 18, 2008, 20:40 »
That was going to be my next suggestion.  ;D
