Author Topic: SP3 How do you know when you have got it?  (Read 2919 times)
Offline Kaz
« on: June 17, 2008, 18:47 »
How do you know when SP3 has downloaded I have Updates set to automatic so how will I know when or if I have already downloaded this? :dunno:
Re: SP3 How do you know when you have got it?
« Reply #1 on: June 17, 2008, 19:20 »
Go into Windows Updates via Start/All Programs and under Options on the left side of the screen you will see "Review Windows Updates".  Click on it and it will tell you if you have  installed it.
« Reply #2 on: June 17, 2008, 19:58 »
Right click on my computer and go to properties and it will tell you there also. If it says service pack 2 or below you don't have sp3 installed.
« Reply #3 on: June 17, 2008, 20:14 »
Do we know if SP3 is safe to download now?
Offline Kaz
« Reply #4 on: June 17, 2008, 21:02 »
I havent got
I haven't got an Options in my All Programs?
« Reply #5 on: June 17, 2008, 21:07 »
Use Reno's method above.  It's easier!
« Reply #6 on: June 17, 2008, 21:12 »
Just open My Documents, go to Help > About Windows and it will tell you there too.  :)
Offline Kaz
« Reply #7 on: June 17, 2008, 21:20 »
Got it I'm still on SP2 oh well will have to wait I surpose thanks for the help again people  ;)
« Reply #8 on: June 17, 2008, 21:33 »
You should be able to get it by visiting Windows Update, Kaz.  :)
Offline Kaz
« Reply #9 on: June 17, 2008, 21:42 »
Think Ill wait till it comes around
« Reply #10 on: June 17, 2008, 21:44 »
You'll know you've got it when the computer stops working.   ;D
« Reply #11 on: June 17, 2008, 21:45 »
:haha:  It's not that bad, Dave, at least, it seems to work OK on mine.  :)
« Reply #12 on: June 17, 2008, 21:48 »
Dave is correct.  I've just carried out a Google search and the issues with SP3 have not been resolved.  Some (like Simon) get away with it whereas others end up with a computer that re-boots itself in an endless loop.   ::)
Offline Kaz
« Reply #13 on: June 17, 2008, 21:52 »
So you have it then Simon did it come in your updates or have you downloaded it from Microsoft?
« Reply #14 on: June 17, 2008, 21:54 »
Ah, I thought that only happened with a certain type of AMD machine, but as mine is Intel, I think I was fairly safe.
I used Windows Updates to get it, Kaz, but as Clive said, if you have an AMD machine, you may want to hold fire on it.
