Author Topic: Possible outage tomorrow - Sat 21/06/08  (Read 5369 times)
Online Simon
« on: June 20, 2008, 22:55 »
We may experience some intermittent outages tomorrow, as our hosts, IDNet, are upgrading one of the core routers from 100Mbps to 1Gbps. They expect the outages to be short as they switch each card and configure it, but the forum may be affected at various points, and anyone with IDNet as their ISP may also experience intermittent email disruptions.
Re: Possible outage tomorrow - Sat 21/06/08
« Reply #1 on: June 21, 2008, 09:59 »
It looks like this should be over now, downtime was less that 5 minutes, and as we share the same server at Netters, I'd expect the effects to be similar.
Of course, there's another hour for them to really play with our minds. ;)
« Reply #2 on: June 21, 2008, 10:11 »
And they did - second outage 10:05-10:10.
« Reply #3 on: June 21, 2008, 11:26 »
Then 10:36-10:39, 10:48-10:53, 10:59-11:02, final one (I hope) 11:08-11:10.
Online Simon
« Reply #4 on: June 21, 2008, 11:34 »
Just as I was trying to get on earlier!   ::)
« Reply #5 on: June 21, 2008, 12:35 »
Well, at least I counted them for you. :)
Online Simon
« Reply #6 on: June 21, 2008, 12:47 »
So, that makes you a Bean counter?   ;D
« Reply #7 on: June 21, 2008, 12:58 »
 :P ;D
Online Simon
« Reply #8 on: June 21, 2008, 13:10 »
It seems that the initial work is complete, but a transceiver slot in the router now needs replacing, which will be done asap.  We will endeavour to inform members of any possible future outages.
« Reply #9 on: June 21, 2008, 18:58 »
I missed it all because I was out all day.  ;D
« Reply #10 on: June 21, 2008, 19:28 »
It wasn't very exciting, Clive. :)
