November 28, 2024, 00:26
Technical Help & Discussion
Broadband, Networking, PC Security, Internet & ISPs
PC soooo slow
Topic: PC soooo slow (Read 1945 times)
KRO
Regular Member
PC soooo slow
June 22, 2008, 14:38 »
help, can anyone suggest any easy repair for my very slow pc, i'm just surfing on my usual websites and it's so painfully slow for some reason.....
cheers kro.....
Re: PC soooo slow
June 22, 2008, 15:57 »
Is it the PC that's slow or your internet connection.
If it's the PC, can you give us a basic spec, eg processor & speed, memory, hard drive & OS.
If it's the latter, what is your downstream sync speed, noise margin & attenuation. Can you do a BT speed test at
http://test.speedtester.bt.com:50301/
Re: PC soooo slow
June 22, 2008, 17:04 »
also have you recently installed any new software / updates...
Re: PC soooo slow
June 22, 2008, 17:26 »
If Rik's speedtester link doesn't work, you might want to try it without the numbers at the end, as I think they are for IDNet customers.
KRO
Regular Member
Re: PC soooo slow
June 22, 2008, 17:57 »
had no luck with that speedtest but i managed this one via AOL keyword if it helps
download 0.52mb
AOLaverage 2.5mb
upload 0.11mb
AOL average 0.3mb
ps i'm afraid this means little to me !!!
cheers kro.....
Re: PC soooo slow
June 22, 2008, 18:09 »
How about your router/modem stats?
KRO
Regular Member
Re: PC soooo slow
June 22, 2008, 18:30 »
netgear wireless ADSL modem router
AMD athlon tm 64 processor 3000+
512 mb DDR
160 GB hard drive
hope this helps...............
cheers kro.....
Re: PC soooo slow
June 22, 2008, 18:39 »
No, I still need the downstream attenuation, noise margin and sync speed from the Netgear.
KRO
Regular Member
Re: PC soooo slow
June 22, 2008, 18:43 »
Quote from: Rik on June 22, 2008, 18:39
rik where / how will i find this info ?
cheers kro.....
Re: PC soooo slow
Reply #9 on:
June 22, 2008, 19:01 »
Log into the router interface, usually 192.168.0.1 for Netgears. Click on the stats button at the bottom of the page.
Re: PC soooo slow
Reply #10 on:
June 22, 2008, 20:20 »
What Rik said, and while you're thinking about that, have you done an anti virus / spyware sweep, and which security software do you use, KRO?
PC soooo slow
