Author Topic: Annoying Mouse Problem  (Read 3890 times)
Offline Big_Boss
« on: March 17, 2003, 20:52 »
As the title suggests i have a mouse problem. The problem is with the scroll wheel. When im using it to scroll down, it scrolls a few lines and then goes up one, and then down a few more and so on.
Has anyone has this problem or got any suggestions about how to fix it? Im sure someone has bound to have had it before.
Thanks
Big_Boss 8)
Offline bat69
Re:Annoying Mouse Problem
« Reply #1 on: March 17, 2003, 21:00 »
Yup, I've had exactly the same problem. However, I didn't solve the problem, my mouse did by breaking and forcing me to replace it :-\
Without knowing what mouse you have etc its difficult to solve the problem, but you are likely to have some software that controls its functions. I'm guessing, but I suspect that you need to adjust the sensitivity of the scroll wheel.
I hope someone can give more positive advice
« Reply #2 on: March 17, 2003, 21:03 »
Try reinstalling or updating the drivers BB and then as Bat suggests look in the mouse properties and set the scroll at the speed/no of lines you want and see if that cures it  :-*
Offline Big_Boss
« Reply #3 on: March 17, 2003, 21:07 »
Ill go look out the floppy driver disk the now  :)
See if that fixes it.
Offline Big_Boss
« Reply #4 on: March 17, 2003, 21:23 »
Just reinstalled the drivers and restarted but no luck  :(
Its a Chic 1330 http://www.chic.com.tw/optical_mouse1.shtml as you requested bat  ;)
Not sure what to try now
« Reply #5 on: March 17, 2003, 21:28 »
Big_boss your mate Robotochan was here on the weekend with another problem with a Chic mouse.
He eventually solved his problem by hitting the mouse on the desk ::)
I don't know, perhaps these Chic mouses respond to violence  ;D ;D
Offline bat69
« Reply #6 on: March 17, 2003, 21:33 »
Do you have any controller software on your PC ... in 'programs' or you may be able to access it through "Control Panel"
If you do, you could try adjusting the sensitivity of the scroll wheel .. change the line rate etc  ... worth a try
Offline Big_Boss
« Reply #7 on: March 17, 2003, 21:33 »
Hmm think ill try reasoning with it first. If it complies alls well, if it doesnt then.... who knows what could happen  ;D ;D
I wont be help responsible 8)
Offline Big_Boss
« Reply #8 on: March 17, 2003, 21:36 »
Yeah it comes with some software which is basically what appears in control panel, ive been fiddling about with it and it doesnt seem to be gettiing any better. Infact think it might be getting worse...but that could be my brain playing tricks on me  ;D
« Reply #9 on: March 17, 2003, 21:44 »
I wonder if they just wear out after a while?  I tend to try to keep the bottom of mine clean, especially the sensor, or it starts playing up.  Perhaps there's some dirt in the wheel?
Offline Big_Boss
« Reply #10 on: March 17, 2003, 21:49 »
Could be i suppose, dunno how the heck im gonna get it out though if it is  :-\
Offline bat69
« Reply #11 on: March 17, 2003, 21:50 »
Try looking at this article there is a section part of the way down about flickering
Are you using the mouse as PS/2 or USB?
Offline bat69
« Reply #12 on: March 17, 2003, 21:55 »
Try blowing hard at it  ;) ;D  lol    well I actually use compressed air in a can with a flexi nozel for those hard to reach places  :o  but I've found that to be a useful piece of kit for both musical instruments, amplifiers and computers, so I tend to have it handy :)
« Reply #13 on: March 17, 2003, 21:56 »
It looks very similar to my Typhoon optical one BB.Have you set it as a 3 button or 5 button mouse and have you got the options for each one set correctly?
Cant think how you could set the wheel do do as you describe but it may be something as silly as that  :-*
Offline Big_Boss
« Reply #14 on: March 17, 2003, 22:44 »
Its a PS2 mouse bat
Read the article but i dont have half of those settings  ;)
Its a 5 button mouse and i think thats how it is set up.  :-\
