Author Topic: AVG disguises fake traffic as IE6  (Read 1299 times)
« on: June 29, 2008, 22:28 »
Re: AVG disguises fake traffic as IE6
« Reply #1 on: June 29, 2008, 22:39 »
It seems a bit over the top scanning websites before you even visit them, doesn't it?
« Reply #2 on: June 30, 2008, 07:54 »
Yes, that's why I have disabled the "link scanner" in AVG. I noticed this as soon as I installed V8, it was taking ages to open a web page.
Double Left click on the AVG icon in the bottom toolbar, it brings up the "Overview" page. Double left click on the "link scanner" enables you to untick the box  "Enable AVG search-Shield"
« Reply #3 on: June 30, 2008, 10:02 »
Good tip, Tony.  :thumb:
Offline David
  • http://Wormdive_2
« Reply #4 on: June 30, 2008, 11:52 »
Thanks Tony it will be interesting as my speeds have been rubbish at times this may cure it... :thumbs: :cheers:
Offline David
  • http://Wormdive_2
« Reply #5 on: June 30, 2008, 13:25 »
Carried this out and Im fine with it.do you get a warning that you may not be protected and a red warning on the shield ?
« Reply #6 on: June 30, 2008, 13:58 »
Yes Dave, if you look at the AVG icon on the bottom left hand of your toolbar, it has lost it's AVG colours, and has a red ring with an explanation mark in it. That's just telling you....all is not functioning as AVG intended......in this case all is running but the "link scanner"
Offline David
  • http://Wormdive_2
« Reply #7 on: June 30, 2008, 14:05 »
 :thanks: could be me but it seems faster would explain a lot as the speed was ok to the router and I had suspected the security stuff.. :thumbs:
Offline David
  • http://Wormdive_2
« Reply #8 on: June 30, 2008, 17:45 »
Well 5 hours later and Im still going fast and furious and have gained some speed  :thumbs:
« Reply #9 on: June 30, 2008, 18:10 »
I've disabled mine too.  It's a brilliant tweak!    8-)
