Author Topic: All programs in XP  (Read 1208 times)
Offline JK
All programs in XP
« on: July 01, 2008, 21:31 »
Hi
I have done something on my PC that makes the Start, All programs list very wide with the last row nearly off the screen. How do I get it back to normal.
Best wishes JK. 8-)
Re: All programs in XP
« Reply #1 on: July 01, 2008, 21:51 »
Hi JK,
If you are using XP, right click the Taskbar (by the Start button) select Properties > click 'Start Menu' tab > click Customise, then tick 'Scroll Programs'.  That should do it.  :)
« Reply #2 on: July 01, 2008, 23:08 »
Neat excuse to buy a widescreen monitor JK.   ;D
« Reply #3 on: July 01, 2008, 23:22 »
Offline JK
« Reply #4 on: July 02, 2008, 15:43 »
Thanks Simon :thumbs:
