Author Topic: Defragger  (Read 2400 times)
Defragger
« on: July 05, 2008, 11:28 »
From everyone here at Piriform, the company that brought you CCleaner and Recuva... we now bring you a file defragmentation tool... Defraggler!
It differs from other defrag tools on the market, by enabling you to quickly and simply defrag the files you want to, without having to process the whole drive. Simply run it, select the file and defragment in seconds. No more struggling with the Windows defragmentation tool!
And remember like all Piriform products, Defraggler is completely free for both corporate and individual use.
http://www.defraggler.com/
Re: Defragger
« Reply #1 on: July 05, 2008, 13:14 »
Umm.... wouldn't only defragging bits of a drive defeat the object?  :dunno:
Offline Baz
Re: Defragger
« Reply #2 on: July 05, 2008, 16:33 »
yeah thats what I thought, how do you know also that you have all the bits and pieces of the file you wish to defrag
Re: Defragger
« Reply #3 on: July 05, 2008, 16:49 »
You can defrag the while drive if you want to.
It looks and works like Windows defragger, but if you click "Analyse" it gives you a list of the fragmented files and then you can choose which (if any) you want to defrag by putting a tick beside them.  On the other hand, if you click "Defragment" it defrags the whole drive.
Re: Defragger
« Reply #4 on: July 05, 2008, 17:22 »
Thanks Dave.  I need to defrag mine so I will try it out.
Offline pcp
Re: Defragger
« Reply #5 on: July 08, 2008, 13:18 »
I've been trying out the latest versions of the commercial automatic defragmenters on Vista and I liked the way the auto defrag feature works.
