Author Topic: Dell Dimension C521  (Read 2870 times)
Dell Dimension C521
« on: July 16, 2008, 19:18 »
Don't you just love friends when they think you know a bit about Pcs  :lol:
Happened to mention that I have built a few over the last 2 years and they think that because you can build a pc that you know it all.. :lol:
Anyway to cut a long story short?
PC duly arrived tonight (on time) plugged everything in, booted up, (running Vista home basic) it get to the bit that runs across the screen at the bottom then it just freezes into a black screen, I have done everything I know how to..like checked all memory/graphics card. it wont even boot into safe mode? so I have the disc that he he had with it when the PC was new (Re installation DVD) tried a repair, it doesn't want to know?..
images below.
The only way I can see round this is to clean install (factory reset) and he will lose everything..
Answers on a post card please.
Re: Dell Dimension C521
« Reply #1 on: July 16, 2008, 19:28 »
hmmm... was it an issue that just happened one day? or is it something that happens occasionally? I'm just wondering if they have gotten stung by a virus or something.. but then again that wouldn't explain the reinstallation dvd giving problems. Is it a dell reinstall dvd or an actual copy of vista?
« Reply #2 on: July 16, 2008, 19:46 »
Its a Dell reinstall DVD, all he said when he booted one day thats all that happened, black screen with the Cursor arrow (it moves) and just sits there with the hard drive icon blinking.
I have checked the memory (ok)
I have checked the Hdrive   (ok)
I have unplugged all the items that are plugged into the Mobo and still the same...it's a mystery to me?
« Reply #3 on: July 16, 2008, 20:31 »
Would resetting the BIOS to fail safe defaults be worth a try?
« Reply #4 on: July 16, 2008, 22:03 »
Cant get to bios neither..or safe mode? when I hit delete to get to the bios nothing happens even when I go to F8 it shows to go to safe mode but get as far as the scrolly thing then black screen with (large ) cursor arrow and just sits there.
« Reply #5 on: July 16, 2008, 22:08 »
It's not a USB keyboard is it?
« Reply #6 on: July 17, 2008, 00:13 »
Some PCs use F1 or F2 for bios, it should say on the first screen which key to press to enter setup.
« Reply #7 on: July 17, 2008, 18:46 »
Reset the bios to factory settings but still no go  :-\
Just found an on board diagnostic screen, running through that at the moment, just awaiting on results.
« Reply #8 on: July 18, 2008, 18:41 »
Still no go, black screen with arrow cursor.
Read through the Dell diagnostic manual , all the green lights 1, 2, 3, 4. are all out and in Dells eyes the system has booted ok..yeah right  :laugh:
« Reply #9 on: July 18, 2008, 20:34 »
Faulty Mobo?  Just guessing.  :dunno:
« Reply #10 on: July 19, 2008, 08:12 »
Clean install plus I've saved all his files ..cool or what  :thumbs: looks like Vista was corrupted in some way, just dloaded over 60 updates over night.
just need to load Office 2003 and he will be back to basics again with a nearly new PC  ::)
« Last Edit: July 19, 2008, 08:14 by TR »
« Reply #11 on: July 19, 2008, 09:44 »
Nice work, Terry.  :thumb:
« Reply #12 on: July 27, 2008, 18:49 »
Terry,
How did you manage to get at his data to save it ?  did you slave his HD on your PC, to get at and save his data?  interested to know how you did it ....grist to the mill and all that
« Reply #13 on: July 27, 2008, 19:01 »
It was simple in the end  ;D
Clean Install over the top of the old system. then it saved a file called "windows.old" 32Gig  :woot: then just cherry picked all the files from that I wanted to save to his hard drive :thumbs:
Hope that helps   :D
« Reply #14 on: July 27, 2008, 21:47 »
You should have upgraded to Windows XP while you were at it Terry!   ;D
