Author Topic: PC Shutdown  (Read 2024 times)
Offline Camstop
PC Shutdown
« on: March 19, 2003, 11:55 »
Since installing windows xp pro....when i shutdown windows my pc is still running and i have to manually hold in the pc on/off button for 5 secs to switch off....
This is annoying... >:( as with previous versions of windows when you click close windows the whole pc switched off....
Think i've had this problem before on an other pc..but i cant remember how to change it to switch off from the mouse.....
Thanks for any help.... ;)
Re:PC Shutdown
« Reply #1 on: March 19, 2003, 12:15 »
I believe this is something to do with the power management settings on your PC not being detected properly by Windows XP.
I'm pretty sure there is a MS Knowledgebase article with a remedy, but I can't find it at the moment. Please wait ... ;) ;D
Re:PC Shutdown
« Reply #2 on: March 19, 2003, 12:24 »
http://support.microsoft.com/default.aspx?scid=kb;en-us;310117 may help, but I'm not sure. I'll keep looking anyway  ::)
Offline Camstop
Re:PC Shutdown
« Reply #3 on: March 19, 2003, 12:52 »
Well look no more... ;)
That worked perfect, just did instructions in reverse...  8)
another satisfied customer...  ;D ;D ;D
Offline Hitch
Re:PC Shutdown
« Reply #4 on: March 19, 2003, 16:30 »
Was just gonna say, right click on your desktop click properties, goto screensaver and power. Click on APM and turn it on.
Was just gonna say that but once again im too bloomin late.
